Sup720 - SSO and ssh issues - Mod 8 continually reboots
Just upgrading our 6513E chassis in the lab before I install it into prod. Wanted to have ssh support, so I upgraded to the latest K9 image.
But as soon as I did that, my standby sup (sso mode) now continually reboots.
I tried an older safe harbour K9 image and same issue.
As soon as I went with a non K9 image, standby sup syncs fine and all is well.
Cheers
Dave
Reza Sharifi Wed, 02/01/2012 - 11:26
  • Cisco Designated VIP,
    2017 LAN
Are you upgrading from a modular code to a non-modular code?
what is the old version and what is the new version you are having issues with?
Reza Sharifi Wed, 02/01/2012 - 11:55
    2017 LAN
Dave
Are you using eFSU to upgrade or simply load the IOS in both flash cards and reboot?
I've tried both ways and same result But I dont think its a K9 related issue anymore as I just tried
s72033-adventerprise_wan-mz.122-33.SXJ2.bin and same issue on mod 8 sup.
So looks like I am having problem running a newer image on the mod 8 720 sup. I am gonna turn off sso and just boot up with mod 8 sup and see if it takes the newer image...
Its a sup720-3b with msfc3...so I should be okay to run the newer images correct ?
Reza Sharifi Wed, 02/01/2012 - 12:25
    2017 LAN
Yes, you should be able to use newer images on your sup-720-3B, as long as you have enough room in your flash.
Are you Sups exactly the same (hardware)?
Just a follow, spent a few hours last night getting to the bottom of it...Looks like there is a bug in IOS versions that was forcing the reboot of mod 8 due to a bulk sync PRC failure. When we looked at the PRC failure it was getting stuck at a boot Bootlolader bootflash statement in the boot variable..It wasnt required so as soon as I deleted it, mod 8 came online as hot standby.
Cheers
Dave
