Warning message
IOS Upgrade Record in Cisco Works?
Answered Question
Feb 1st, 2012
Hi, I am little new to cisco works, and unable to find log that can show me which devices had IOS upgrade in last 1 month or year etc.
is it possible to check from cisco works? if yes, where exactly.
thanx.
Correct Answer by Marvin Rhoads about 5 years 6 months ago
There is a report called "Change Audit Report". Among other things, it will tell you:
Software Management—The Software Modification History report is displayed.
This window shows the changed software image details.
I'm not sure if it will tell you if the software was upgraded "manually" (i.e., not as part of an LMS-initiated job).
Have a look at this link and see if it does what you're looking for.
Overall Rating: 5 (1 ratings)
Correct Answer
Marvin Rhoads Wed, 02/01/2012 - 11:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
ahmad82pkn Wed, 02/01/2012 - 12:04
i found the option But looks like i didnt upgraded any IOS, since its not showing me any result, may be i didnt upgrade any thing after adding them in cisco works, i ll check on this.
thank you
