Warning message
Ip phone is not registering on CME
Feb 1st, 2012
Hi voice team!!
I did the SRST configuration and work properly in my environment...
But when I turned back the old configuration "CME" all ip phones are dropping packets and it is not registering:
Resposta de 10.100.2.59: bytes=32 tempo=1ms TTL=64
Resposta de 10.100.2.59: bytes=32 tempo<1ms TTL=64
Esgotado o tempo limite do pedido.
Resposta de 10.100.2.67: Host de destino inacessível.
Resposta de 10.100.2.59: bytes=32 tempo=1996ms TTL=64
Resposta de 10.100.2.59: bytes=32 tempo=998ms TTL=64
Resposta de 10.100.2.59: bytes=32 tempo=997ms TTL=64
thanks..
Chris Deren Wed, 02/01/2012 - 12:03
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Delete ITL certificates from the phones.
Chris
Chris Deren Wed, 02/01/2012 - 12:44
  • Hall of Fame,
On the phone go to secuirty setting, on 79XX it is under Settings --> Secuirty --> trust list --> ITL,  unlock the phone (**#), select more softkey and chose Delete.
Chris
