Warning message
5505 7.2(4) - PAT Multiple to one inside.
Answered Question
Feb 2nd, 2012
Hi Guys,
I have a 5505 IOS V7.2(4).
I am trying to add 2 static PATs using 2 external IPs to a single internal IP.
This is what we have in place already and is working fine:
static (inside,outside) tcp 77.xx.xx.206 www 10.xx.xx.2 www netmask 255.255.255.255
static (inside,outside) tcp 77.xx.xx.206 https 10.xx.xx.2 https netmask 255.255.255.255
I am wanting to add another external IP to this and PAT it to the same internal destination, so the outcome should be:
static (inside,outside) tcp 77.xx.xx.205 www 10.xx.xx.2 www netmask 255.255.255.255
static (inside,outside) tcp 77.xx.xx.205 https 10.xx.xx.2 https netmask 255.255.255.255
10.xx.xx.2 is a VIP running on a par of NetScalers.
I know it possible on the 8.3 IOS to have a One -to- Many Static NAT.
Does anyone Know if it’s possible or how to correctly configure this? As when I try applying the config it errors (ERROR: duplicate of existing static).
Dale
Correct Answer by Julio Carvajal about 5 years 6 months ago
Hello Dale,
Lets trick the ASA:
Acess-list test1 permit tcp host 10.xx.xx.2 eq 80 any
static (inside,outside) 77.xx.xx.205 access-list test1
Julio
Overall Rating: 5 (1 ratings)
Correct Answer
Julio Carvajal Thu, 02/02/2012 - 11:13
  • Purple, 4500 points or more
Hello Dale,
Lets trick the ASA:
Julio
r_drogerson Mon, 05/14/2012 - 08:21
Hi Julio,
Sorry for the not responding sooner, your fix worked a charm.
Dale
Julio Carvajal Mon, 05/14/2012 - 10:08
Hello Dale,
My pleasure, Glad I could help.
Julio
Related Content
