A question about the syntax of ACLs
Feb 2nd, 2012
Hello All,
I hope I'm openning this in the right place.
I have a question about the syntax of Cisco ACLs.
I have configured an ACL on my router using service-objects and network-objects in the service, sourceIP, and destinationIP fields of my ACL and it seems that the router changed the syntax of the ACL, the below line is taken fron the show running-config command:
access-list 123 permit not nbject-group evg_ser not1object-group evgeny dfobject-group shay log
and this line is taken from the show access-list command:
10 permit object-group evg_ser object-group evgeny object-group shay log
My question is, what is the 'not' and the 'not1' strings in the config line above (I didn't write down this two strings - the router added them by itself)
Maybe a bug?
Thank you
Marvin Rhoads Thu, 02/02/2012 - 07:11
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Your output from the show running-config with the "not" and "not1" strings seems bizarre. I would not expect these strings to even be accepted by the router's command parser.
I suspect they may be an artifact of your terminal emulation tool. What are you using to log in (e.g., Putty, XShell, SecureCRT, Hyperterm, etc.)? Are you going in via vty or console? I'd try a different tool and/or method and see if you get the same output.
shaijosef Thu, 02/02/2012 - 07:33
Thanks for you answer.
I'm using Putty or Telnet through a regular VTY line.
Richard Burts Fri, 02/03/2012 - 10:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
What platform is this and what version of code. Posting the output of show version might be helpful.
Rick
shaijosef Mon, 02/06/2012 - 00:27
Hi, the complete output of show version is displayed below:
Router2801#sh ver
Cisco IOS Software, 2801 Software (C2801-ADVSECURITYK9-M), Version 12.4(20)YA3,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 03-Apr-09 20:19 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Router2801 uptime is 3 days, 19 hours, 14 minutes
System returned to ROM by reload at 13:15:56 UTC Thu Feb 2 2012
System image file is "flash:c2801-advsecurityk9-mz.124-20.YA3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2801 (revision 5.0) with 118784K/12288K bytes of memory.
Processor board ID FTX0942W0U7
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Related Content
