NSS 6000 RAID gone
Feb 2nd, 2012
The other day on my NSS6000 I got a RAID running degraded message.
I look and one of the 4 drives isn't added to the RAID.  I re-add it and it takes 36-40 hours to rebuild the RAID, I get a success message.
When I look at all the drives they say healthy.
Under Storage /RAID I see:
RAIDA
raid5No----Stopped
When I go to start the RAID, I get an error of:
Failed to start RAID
Please check that all components are present
Can anyone suggest what to do here? I have taken the drives out of this NSS and put into a spare one with the same result.
Thanks in advance!
jasbryan Mon, 02/13/2012 - 09:56
  • Silver, 250 points or more
John,
depending on what your logs shows, but it sounds like you lost more than one drive from your array which will cause a fatal error and stop the array. I have also seen multiple brownouts, blackouts cause Fatal RAID corruption which causes the RAID to stop.
If you lost more than 1 drive then you'll need to completely reconfigure ARRAY!
Jasbryan
torschitzschanes Tue, 09/24/2013 - 23:50
I also have a stopped RAID. One disk was defect, but this was a contact problem from disk to circuit board.
The disks are all ok according to the administrator interface from the NSS6000. Smart Status OK.
Booting is also ok - only starting RAID ist not possible. Do you know any hint or trick to start an array?
Thank you.
Best regards
