Confused about the ACE
Feb 2nd, 2012
hI
Just done a course on the ace and seem to be having some trouble with the virtual side
of things.
I am trying to work out why i cant ping out of my virtual instance Testing-11
I have set up the following vlan ....
vlan 1000 10.x.x.21 255.255.255.0
However when i look at it in the virtual instance i get this ....
vlan1000 is down, VLAN not assigned in Admin
Yet it says Assigned on the physical port, up on the physical port
However on the admin side i have this vlan 1000 and there it is
vlan1000 is up, VLAN up on the physical port
I thought that you had to have the vlan assigned to a physical port
on the admin side - it is but it doesnt work !!!!
Well not in the Virtual instance
I had assumed that all you had to do was to assign the vlan to a physical
port and allocate it to the virtual instance and you should be able to get
there from outside as long as you have the relevant
Policies allowed - is that correct ?
I have another vlan 100 and that has come up ok...
Steve
Jorge Bejarano Thu, 02/02/2012 - 09:20
  • Silver, 250 points or more
Hello Steve,
Did you allocate the vlans to the new context?
Did you configure a class-map type management in the new context?
Here you have a document with additional information:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/virtualization/guide/config.html
Hope this helps
Jorge
Cesar Roque Thu, 02/02/2012 - 17:31
  • Bronze, 100 points or more
Hi Steve,
You just need to allocate the VLAN you want to use to the User Context.  You have to do this in the Admin Context
For example:
ACE-4710A/Admin(config)# context test
ACE-4710A/Admin(config-context)# allocate-interface vlan 1000
Cesar R
