Warning message
Adding 1 to all outgoing calls
Feb 2nd, 2012
I have recently set up a new SIP provider on a UC560 that requires all numbers be 11-digit numbers starting with a 1. Is there any good way to have an outgoing dial-peer to translate all numbers dialed without 1 to add a 1 and the same time if someone does add a 1 a to the number they are dialing that system will treat it normally?
Overall Rating: 5 (1 ratings)
Mario Garcia Thu, 02/02/2012 - 18:51
Via CLI you can in the dial-peer to prefix a 1
pennautomotive Thu, 02/02/2012 - 18:55
Do you mind providing an example? Even sudo-code would be appreciated.
Mario Garcia Thu, 02/02/2012 - 19:02
Basically gain access via CLI
Located the dial-peer, commands as follows when in enable mode
Conf t
Dial-peer voice XX pots
Prefix 1
End
"XX" is the dial peer number you want to edit.
Let me know if you need additional commands
-Mario
