02-02-2012 04:25 PM - edited 03-16-2019 09:22 AM
I know this sounds like a silly question, but I'm trying to set the device CSS on a pilot point - not the line CSS. It's not a drop down box when you look at the pilot point configuration. I've found and set it before, however it appears I did not take good notes. I remember it was sort of a backwards way to control the device without actually being in the Pilot Point configuration. Any thoughts?
CUCM 7.15.
02-02-2012 05:13 PM
are you referring to hunt pilot? If so there is no separate device and line, there is only one CSS. Perhaps you recall cti route point?
02-02-2012 05:17 PM
No. Pilot Point.
Application - Cisco Unified CM Attendant Console - Pilot Point.
I know you don't see a CSS drop down box when you're looking at it from the Pilot Point configuration page (normal view). There is a sneaky way. I see all my other Pilot points have the device CSS set (as well as DN CSS).
02-02-2012 05:50 PM
Found it. I setup a Pilot point with device name=XXX. I complete the DN, and hunt group stuff. I then search for CTI route points with the device name = XXX. I can now set the device CSS for the Pilot point.
