AP showing down status in WLC
Feb 2nd, 2012
hi,
I have cisco wlc 4404 and access point 1242AG A-K9
when I try to connect ap to WLC, it is showing me down status
when i take hyperterm of AP, one of the radio interface status showing me as administratively down.
Overall Rating: 5 (1 ratings)
Scott Fella Fri, 02/03/2012 - 03:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Did you enable the admin status for that ap in the wlc? You have the radios also enabled on the wlc?
Scott Fella
Sent from my iPhone
nikhilcherian Fri, 02/03/2012 - 03:35
  • Bronze, 100 points or more
Please check the following
1. The AP radio interface is not adminstratively shutdown from inside the AP
2. AP is getting enough power
3. The ADMIN status is up from the WLC
NikhiL
vishalpatil86 Fri, 02/03/2012 - 06:42
admin status is enable
pls find the attachment for your further understanding of the problem
joined ap ha 802.11a supported while down ap not
what shuld i do now?????
Scott Fella Fri, 02/03/2012 - 06:47
  • Hall of Fame,
    2017 Wireless
What is the model number on that You would need to at the country domain in the wlc for that ap in order for that radio to be enabled.
Scott Fella
Sent from my iPhone
nikhilcherian Fri, 02/03/2012 - 06:55
Can you put the following outputs
From AP
show controllers dot11radio 1
show controllers dot11radio 0
sh ip int brief
From WLC
show country
NikhiL
vishalpatil86 Fri, 02/03/2012 - 20:42
hi
nikhilcherian,
attached the output of above commands....
(Cisco Controller) > show country
Configured Country ---------------------------- IN   - India
Configured Codes
      IN   -   India -----------------------------------------802.11a, Indoor, Outdoor
/  802.11b  /  802.11g
Leo Laohoo Fri, 02/03/2012 - 21:08
  • Hall of Fame,
    2017 LAN, Wireless
The only time I see a WAP's radio won't come up is when it's connected to a power injector and then to a 2950.  Can you confirm this is so?
vishalpatil86 Fri, 02/03/2012 - 21:28
no, its not like that...
i connected to 2960, same is happening
nikhilcherian Fri, 02/03/2012 - 21:48
Vishal,
Your WLC is in India Domain, which doenst support A radio, while your ap is US domain which support both A radion and b/g Radio
Please paste the "show ip interface brief" also
Is any other AP in your network broadcasting in A domain
NikhiL
nikhilcherian Fri, 02/03/2012 - 21:52
Last radio reset code: 54 , this is the reason for your radio reset, Please check the below
https://supportforums.cisco.com/thread/2120330
It says the reason as
Status 54: Radio interface was shutdown -- either configured by the user or perhaps part of the boot process.
NikhiL
vishalpatil86 Fri, 02/03/2012 - 22:09
hi,
Interface                  IP-Address      OK? Method Status                Prot
ocol
Dot11Radio0                unassigned      NO  unset  up                    up
Dot11Radio1                unassigned      NO  unset  administratively down down
FastEthernet0              172.16.10.100   YES other  up                    up
yes, there are other APs that are in A domain, but the model number is different 1242AG N-K9
and I am facing problem with 1242AG A-K9
nikhilcherian Fri, 02/03/2012 - 22:12
in the AP do the following steps
ap#debug capwap console cli
ap(config)# int d1
ap(config-if)# no shutdown
Looks like some one has made your interface admin down
NikhiL
vishalpatil86 Fri, 02/03/2012 - 22:18
i have done that already, but when i try to copy run startup config, it is giving me an NVRAM verification failed error
AP#wr
Building configuration...
[OK]
NVRAM Verification Failed
Business_Centre#wr
[OK]
nikhilcherian Fri, 02/03/2012 - 22:20
That is fine, can you do that and check the output of "show ip int brief" again
nikhilcherian Fri, 02/03/2012 - 22:36
Enable the radio, save the config and reload it. And paste the output "more flash:event.log" from AP
NikhiL
nikhilcherian Sat, 02/04/2012 - 06:01
The log says
*Feb 4 09:52:11.421: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 4 09:52:11.583: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Feb 4 09:52:11.688: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Feb 4 09:52:11.688: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
Which is happening after the AP has joined the WLC, this can primarly becoz the WLC in India domain doesnt support A radio. But it is little surprising that you say there is already an AP with a radio up
Please send the detail of that AP also
NikhiL
nikhilcherian Mon, 02/06/2012 - 02:05
sh ip int brief
show capwap client rcb
NikhiL
nikhilcherian Tue, 02/07/2012 - 04:10
interface Dot11Radio1
Radio AIR-AP1242A, Base Address 0024.c352.bac0, BBlock version 0.00, Software version 6.30.33
Serial number: ALP13041YP2
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: MX-AU-NZ (MX) (-N)
This is from your joined AP, while not joined AP have the below output
Radio AIR-AP1242A, Base Address 003a.9a0d.d660, BBlock version 0.00, Software version 6.30.33
Serial number: ALP153666CP
Carrier Set: Americas (OFDM) (US) (-A)
nikhilcherian Tue, 02/07/2012 - 05:15
That is the only difference that could be figured out from your AP, the joined AP is in N domain while the not joined AP is in the A domain. This may be affecting your AP a domain
NikhiL
vishalpatil86 Tue, 02/07/2012 - 08:16
how can i fix it???
let me know the configuration changes i need to do in AP or wlc....
Stephen Rodriguez Tue, 02/07/2012 - 08:18
  • Purple, 4500 points or more
You would need to enable US in the country list on the WLC.
nikhilcherian Tue, 02/07/2012 - 08:42
Check out if it legal to use the 802.11a radio in your location
NikhiL
