C40 not booting
Feb 3rd, 2012
Having problems with our TelePresence Intergrator C40. I wasn't present for the change, but another tech changed the IP, GW, etc and rebooted through the web interface. Once it rebooted it never came back up. Connecting to the codec serial port I get the following message:
Couldn't connect to TANDBERG software.
I've attached the full boot sequence. Any ideas of how I can get an OS uploaded or to fix this?
My hands are tied, not getting a response from the vendor, I took over this system which was put in place 3 months ago and I'm unable to get ahold of the people that coordinated the install. The S/N is registered to another support contract not covered under any of my contracts associated with my profile when trying to open a TAC and I'm getting alot of heat to get this thing fixed ASAP.
Thanks for any help!
-Dave
Overall Rating: 4.7 (7 ratings)
Teck Chye Tang Fri, 02/03/2012 - 22:19
  • Cisco Employee,
hi,
Try connecting a serial cable to the codec and reboot the codec. Stop the boot by pressing 'b' and 'c'( you should see the instruction on yr pc screen) then you should see the AMERICA > prompt.
Type selectsw and you should see 2 image. Try to select and boot up from the non active one. E.g If image 1 is the current active one, the you choose Omar 2 by sending this selectsw image2, then reboot your codec to see of it boots up.
vivsing2 Sun, 02/05/2012 - 10:20
  • Bronze, 100 points or more
As steps mentioned by Teck will work if you have their are two software on your system, please let us know, if above worked for you or not.
There is another way through which we can store new software, let me know i can mail you files required and steps to complete process.
Vivek
AHMAD HASSAN Wed, 02/08/2012 - 05:07
Hi All,
i have same problem on C20, when try selectsw command i found only one image" image1 active"
how can I store the new software to the device?
Thank's
Ahmad Hassan
Teck Chye Tang Wed, 02/08/2012 - 16:55
  • Cisco Employee,
Ahmad,
So your codec cannot boot up properly or is it in a constant reboot state?
Can you ssh/scp to the unit and try to remove the config.db file and see if that helps.
Else, send me your email and can email the files and steps to you to use tftp to transfer files to the codec.
AHMAD HASSAN Thu, 02/09/2012 - 01:23
The device didn’t boot at all, the front led keep flashing green.
Can you send me the file and the steps to load the software.
Best Regards,
Ahmad Hassan
Best Regards
Ahmad Hassan Ahmad
Technical Support Engineer
Visual-Communication Division
Description: Description: cid:[email protected]
Egyptian Micro Solutions
Tel : +202- 240 14 583
Fax : +202- 2261 41 31
Mobile: +20- 0111 006 12 81
8 Abou Zar El-Ghefari St.-7th District
Nasr City - Cairo -Egypt
Email : [email protected]
Website: www.emsegypt.net
Teck Chye Tang Thu, 02/09/2012 - 01:55
  • Cisco Employee,
I have sent the details to you to your email.  Please try and feedback.
justinalexander Wed, 02/29/2012 - 06:58
Can you send me those details also?
Having the same issue with a C40, but I do see both image1 and image2 (active 2), now if I try to make image 1 active it just keeps rebooting and image 2 gives me the error "Couldn't connect to TANDBERG software".
I'll probably call into tech support within the hour if I don't hear back.
Justin alexander
[email protected]
vivsing2 Wed, 02/29/2012 - 07:02
Hi Justin,
Please use serial cable and break boot process using
prompt b and c
type following command
  • setenv othbootargs noboot allowroot
after that login as root
type cd /mnt/base/active
rm config.db
and reboot your codec
Anthony Chan Wed, 02/29/2012 - 08:37
I had that same issue back in Dec where two of my brand new C60 codecs acted in the same similar fashion
it kept rebooting
btw what does removing the config.db do?  does it refresh the system?
would you be able to send me those steps as well just in case another codec acts this way and i wont be in frantic to get the  unit back up or count on the active responses from my supplier
our resolution at that time was for Cisco to send us to new units as we needed to get the system up in the next two days and they were brand new units so not sure what happened?
Anthony
vivsing2 Wed, 02/29/2012 - 08:44
Let me provide all steps:
1  Connect a serial cable to the system at 38400, 8, N, 1
2  Reboot the system, and hold b until “Press 'b' to enter u-boot” message appears
3  Press c to stop auto boot, then SATURN> or AMERICA> or anyname> prompt will return.
4 type command setenv othbootargs noboot allowroot then hit enter this will not return anything
5 type boot or reboot, this will reboot codec
Till this step you stoped codec to move into boot cycle and will enable root login without password
6. After codec completed reboot cycle, then it will prompt for login: login with root
7. type command: cd /mnt/base/active
6. type command: rm config.db
this is one of the wat through which you can refresh your codec and it's high level factory reset
7. type command: boot or reboot
8. After this you can login in codec after system come up from reboot
Let me know if oyu required anyother detail and please rate as well.
Vivek
vivsing2 Thu, 03/15/2012 - 20:42
Hi Jo,
Please provide me last line which you are getting on screen, where it stuck.
Vivek
Paulo Ferreira Tue, 03/27/2012 - 03:28
Hello Vivek,
I have a C40 that constantly reboots.
I follow your procedure but after the commnad "setenv othbootargs noboot allowroot " I tryed to boot but I received the message: "
Wrong Image Format for bootm command
ERROR: can't get kernel image! Wrong Image Format for bootm command
ERROR: can't get kernel image!"
And now? Can you help me?
Paulo Ferreira
mubakhta Tue, 03/27/2012 - 04:25
  • Silver, 250 points or more
Hi Paulo,
My name is Mubashshir and I am from the Telepresence Support Team. The error says that it cannot find the kernal image. It looks like that the software file has been either deleted or corrupted. I think you should start reload a fresh copy of the software image to the codec and the codec will then boot up without issues.
Please follow the steps mentioned in the following link :
https://supportforums.cisco.com/docs/DOC-23161
Once, you install a fresh software image, it would come back fine. If you face any other issues, please feel free to let us know.
Mubashshir Akhtar
vivsing2 Tue, 03/27/2012 - 05:16
Hi Paulo,
I think, software image of your system is completly corrupted, hence due to which it's not even allowing us to login in root. It appears its not your config failure, its image failure.
So i think this document will help you to install new image replacing corrupted image.
Vivek
Paulo Ferreira Tue, 03/27/2012 - 05:43
Hi Mubashshir and Vivek,
thanks for the document.
But I am doing something wrong, because the C40 doesn't get the file from TFTP server:
"AMERICA> setenv serverip 172.20.9.31
AMERICA> setenv tftp_path pkgfiles
AMERICA> setenv americapkg s52000tc5_1_0.pkg
AMERICA> run pkgex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
BOOTP broadcast 1
I have the codec conected to PC just with a serial cable. The files are in the indicated folder and TFTP current directory is point to this one...
Thanks for your help.
regards
Paulo Ferreira
vivsing2 Tue, 03/27/2012 - 05:59
Hi Paulo,
You are going in right direction, that's great .
I have one more suggestion you need to enable DHCP service on tftpd software and you also need to connect your Laptop/Pc connected to Codec with Crossover cable and serial cable.
Serial cable ensure that you have output all the time on your Laptop/PC and LAN cable ensure that file is going from your Laptop/PC to Codec.
Vivek
mubakhta Tue, 03/27/2012 - 06:54
Hi Paulo,
As Vivek mentioned, we would require a DHCP server for this to work. Please setup the DHCP server using these settings :
Then try to perform the above operation again. If you still get this issue, that means that the IP address on the codec is set to be static and not by DHCP. Type the following command in the SATURN or AMERICA prompt:
dhcp
This would grab the IP address from the laptop's DHCP server and then you can follow the operation again.
However, in case the codec is not getting the IP address from the DHCP server, we need to make sure that there is connectivity between the laptop and the codec.
Mubashshir Akhtar
Paulo Ferreira Tue, 03/27/2012 - 07:04
Hello again to all,
and thanks for your help, the codec is finally with a correct software image.
But now I'm back to the intitial point: constant reboot of the codec, I can't even digit the user and password......
Paulo Ferreira
mubakhta Tue, 03/27/2012 - 07:15
Hi Paulo,
Can you try these steps again to enable root account in case of constant boot :
Also, when you reach the AMERICA prompt, please type selectsw and check which image is active out of the two. It seems that the codec is still booting from the corrupted image.
Mubashshir Akhtar
vivsing2 Tue, 03/27/2012 - 07:35
Hi Paulo,
So after codec recovered, you are not able to login, did you made any configuration changes ?
are you getting login prompt on Codec or anything ?
Do one thing disconnect all the connection from codec except serial and let me know, whether codec still in bootcycle ?
Vivek
Paulo Ferreira Tue, 03/27/2012 - 07:51
sometimes I'm able to digit the password but just that, then the codec reboots again. Some other times shows ,after digiting the pass admin, the word tsh.
And the other times I'm not even can digit the password, appears the text: "shell: Remote closed connection".
I already tryed with the command: "setenv othbootargs noboot allowroot ".
Vivek, I'm not able to change configuration.
Paulo Ferreira
vivsing2 Tue, 03/27/2012 - 08:12
Hi Paulo,
I think image is now loaded; however due to some reason may be some conflict or something.
As you mentioned that there is nothing connected, so it seems that something in config is leading issue, not sure when there is no config change.
Now there is something fast we need to do, i would request one las time time to use
and then reboot codec using , boot/reboot command
when login prompt appear, login as root, then you will get prompt like
run command
rm /mnt/base/active/config.db
and typr command reboot and let me know reasult.
Vivek
mubakhta Tue, 03/27/2012 - 07:52
Paulo,
Before we go to intense troubleshooting on this, can you verify something basic. I believe I know what the problem is. Can you check where you have plugged the Camera Control cable on your Camera? You might have plugged it in the Ethernet port which is causing the cyclic reboot. The Camera control cable needs to be plugged in the Visca Camera Control Port. Please check the screenshot below :
Please make sure that this is not what the issue is and update with the results.
Mubashshir Akhtar
Paulo Ferreira Tue, 03/27/2012 - 07:56
Hi Mubashshir,
that is not the reason, because I have the codec uplugged from everething. I just have the power cable and serial cable connected.
mubakhta Tue, 03/27/2012 - 08:20
Hi Paulo,
Are you able to get to the AMERICA prompt ? Can you verify by running the command selectsw to check which image is active and also to see if there are two images in the codec, one showing as active.
If yes, then can you type :
selectsw
Please try this and update with the results.
Mubashshir Akhtar
Paulo Ferreira Tue, 03/27/2012 - 08:39
Hi Mubashshir,
"AMERICA> selectsw
yaffs: Mounting /flash
image1          [ACTIVE]
AMERICA> "
regards
Paulo Ferreira
vivsing2 Tue, 03/27/2012 - 09:04
Hi Paulo,
Have you tried steps in my previous mail after new software image process.
Vivek
Paulo Ferreira Tue, 03/27/2012 - 09:10
Hello Vivek,
Yes I tryed but the problem remains.
Paulo Ferreira
vivsing2 Tue, 03/27/2012 - 09:21
Hi Paulo,
I sent one message to you with one suggestion.
Vivek
mubakhta Tue, 03/27/2012 - 09:35
Hi Paulo,
I just noticed in one of your messages above you mentioned that you ran the following command :
I believe the command you need to run is :
Setenv saturnpkg
In this case it should be :
AMERICA> Setenv saturnpkg s52000tc5_1_0.pkg
Can you please try the process again with this command and update?
Mubashshir Akhtar
Paulo Ferreira Tue, 03/27/2012 - 09:42
Hi Mubashshir,
Yes, I also notice that previously and I correct that. The final result was the same.
Paulo Ferreira
mubakhta Tue, 03/27/2012 - 12:03
Hi Paulo,
At this time we have exhausted all the troubleshooting. I would recommend you to open a TAC case with us for this issue and we can maybe take a webex session and perform the whole operation ourselves to make sure its working fine. We will make sure that this issue is taken care of in a timely manner.
Mubashshir Akhtar
mubakhta Tue, 03/27/2012 - 15:46
Hi Paulo,
Before we go ahead with the TAC case, can you please  try to perform one more step. I was researching on the issue and I think  I have found out the problem.
Can you please download  the package file for TC4.2.2 and then try to perform the operation  again?
Here's the link of the download :
ftp://ftp.tandberg.com/pub/software/endpoints/tc/tc4/s52000tc4_2_2.pkg
Please  try the steps again only the difference is to replace your current  package file with this one. Also since the package file is changing, the  commands in the SATURN prompt would also change to the new filename.
Please try these steps and update with the results.
Mubashshir  Akhtar
mindaugaskrilavicius Thu, 04/12/2012 - 05:59
Hello, can somebody help for me. I try upload new software for my Tandberg c20, and happen sonthing wrong - cant no upgrade no downgrade,  so with this directions try fix https://supportforums.cisco.com/docs/DOC-23161, but not luck.
I think maybe    pkgextract.elf   and u-boot not suitable for C20?
Because C20 name is ORION
I made log when try upload software, maybe make some problem?
How I can Fix this, because now tandberg dont start
Log:
Press 'b' to enter u-boot prompt
Press 'c' to stop autoboot:  4
ORION> setenv serverip xxx.xxx.134.206
ORION> setenv tftp_path pkgfiles
ORION> setenv orionpkg s52000tc2_0_1.pkg
ORION> run pkgex
BOOTP broadcast 1
DHCP client bound to address xxx.xxx.134.209
NAND erase: device 0 whole chip
Skipping bad block at  0x09b40000
Skipping bad block at  0x0ea40000
Skipping bad block at  0x27640000
Skipping bad block at  0x48700000
Skipping bad block at  0x4d980000
Skipping bad block at  0x582c0000
Skipping bad block at  0x7cb40000
Erasing at 0x7ffc0000 -- 100% complete.
OK
Using TSEC0 device
TFTP from server xxx.xxx.134.206; our IP address is xxx.xx.134.209
Filename 'pkgfiles/saturn.pkg'.
Load address: 0x2000000
Loading: *
TFTP error: 'File not found??f•wabcdefghi??×ö' (1)
Not retrying...
Copy pkgextract.elf from NOR flash to 0x1000000
## Starting application at 0x00042e78 ...
Buildtime: Jan  4 2012 11:31:59
Not a PKG file (170173190)
Failed to read PKG header
## Application terminated, rc = 0x1
image1 is not a directory
Reprogram NOR from /flash/image1
Un-Protected 1 sectors
. done
Erased 1 sectors
Copy /flash/image1/bootsw to 0x01000000... File not found
Write /flash/image1/bootsw (4294967295) to NOR flash
NOR allready contains correct data
Copy /flash/image1/pkgextract.elf to 0x01000000... File not found
Write /flash/image1/pkgextract.elf (4294967295) to NOR flash
File /flash/image1/S01710.bin.wrapper not found
ORION> Orion
Unknown command 'Orion' - try 'help'
ORION>        SN: F1AN2
Unknown command 'SN:' - try 'help'
ORION>        SN: PB039 TSEC1
ORION> Hwmon: 43
Unknown command 'Hwmon:' - try 'help'
ORION> Press erverip 210tc2_0_1.pkg
Unknown command 'Press' - try 'help'
ORION> ORION> run pkgexe: device 0 whole chip
Unknown command 'ORION>' - try 'help'
ORION> Skipping bad blox27640000
Unknown command 'Skipping' - try 'help'
ORION> Skipping bad blo582c0000
ORION> Skipping bad blo/flash
ORION> Using TSE0 device 'pkgfiles/saturn.pkg'.
Unknown command 'Using' - try 'help'
ORION> Load address: 0xretrying...
Unknown command 'Load' - try 'help'
ORION> Copy pkgextract.Buildtime: Jan  4 2012 11:31:59
Unknown command 'Copy' - try 'help'
ORION> Not a PKG file (image1 is not a directory
Unknown command 'Not' - try 'help'
ORION> Reprogram NOR frlash/image1/bootw to 0x01000000... File not found
Unknown command 'Reprogram' - try 'help'
ORION> Write /flash/imaflash/image1/pkgextract.elf to 0x01000000... File not fou
nd
Unknown command 'Write' - try 'help'
ORION> Write /flash/imadata
ORION> File /flash/imag
Teck Chye Tang Thu, 04/12/2012 - 06:07
  • Cisco Employee,
Do not change the name to Orion, leave it as Saturn
mindaugaskrilavicius Thu, 04/12/2012 - 06:21
But now then try reply I get this...
LOG:
setenv serverip 213.226.134.206
ORION> setenv saturnpkg s52000tc2_0_1.pkg
ORION> run pkgex
BOOTP broadcast 1
Erasing at 0x0 --   0% complete.Erasing at 0x1440000 --   1% complete.Erasing at 0x28c0000 --   2% complete.Erasing at 0x3d40000 --   3% complete.Erasing at 0x51c0000 --   4% complete.Erasing at 0x6640000 --   5% complete.Erasing at 0x7ac0000 --   6% complete.Erasing at 0x8f40000 --   7% complete.Skipping bad block at  0x09b40000
Erasing at 0xa3c0000 --   8% complete.Erasing at 0xb840000 --   9% complete.Erasing at 0xccc0000 --  10% complete.Erasing at 0xe140000 --  11% complete.Skipping bad block at  0x0ea40000
Erasing at 0xf5c0000 --  12% complete.Erasing at 0x10a00000 --  13% complete.Erasing at 0x11e80000 --  14% complete.Erasing at 0x13300000 --  15% complete.Erasing at 0x14780000 --  16% complete.Erasing at 0x15c00000 --  17% complete.Erasing at 0x17080000 --  18% complete.Erasing at 0x18500000 --  19% complete.Erasing at 0x19980000 --  20% complete.Erasing at 0x1ae00000 --  21% complete.Erasing at 0x1c280000 --  22% complete.Erasing at 0x1d700000 --  23% complete.Erasing at 0x1eb80000 --  24% complete.Erasing at 0x1ffc0000 --  25% complete.Erasing at 0x21440000 --  26% complete.Erasing at 0x228c0000 --  27% complete.Erasing at 0x23d40000 --  28% complete.Erasing at 0x251c0000 --  29% complete.Erasing at 0x26640000 --  30% complete.Skipping bad block at  0x27640000
Erasing at 0x27ac0000 --  31% complete.Erasing at 0x28f40000 --  32% complete.Erasing at 0x2a3c0000 --  33% complete.Erasing at 0x2b840000 --  34% complete.Erasing at 0x2ccc0000 --  35% complete.Erasing at 0x2e140000 --  36% complete.Erasing at 0x2f5c0000 --  37% complete.Erasing at 0x30a00000 --  38% complete.Erasing at 0x31e80000 --  39% complete.Erasing at 0x33300000 --  40% complete.Erasing at 0x34780000 --  41% complete.Erasing at 0x35c00000 --  42% complete.Erasing at 0x37080000 --  43% complete.Erasing at 0x38500000 --  44% complete.Erasing at 0x39980000 --  45% complete.Erasing at 0x3ae00000 --  46% complete.Erasing at 0x3c280000 --  47% complete.Erasing at 0x3d700000 --  48% complete.Erasing at 0x3eb80000 --  49% complete.Erasing at 0x3ffc0000 --  50% complete.Erasing at 0x41440000 --  51% complete.Erasing at 0x428c0000 --  52% complete.Erasing at 0x43d40000 --  53% complete.Erasing at 0x451c0000 --  54% complete.Erasing at 0x46640000 --  55% complete.Erasing at 0x47ac0000 --  56% complete.Skipping bad block at  0x48700000
Erasing at 0x48f40000 --  57% complete.Erasing at 0x4a3c0000 --  58% complete.Erasing at 0x4b840000 --  59% complete.Erasing at 0x4ccc0000 --  60% complete.Skipping bad block at  0x4d980000
Erasing at 0x4e140000 --  61% complete.Erasing at 0x4f5c0000 --  62% complete.Erasing at 0x50a00000 --  63% complete.Erasing at 0x51e80000 --  64% complete.Erasing at 0x53300000 --  65% complete.Erasing at 0x54780000 --  66% complete.Erasing at 0x55c00000 --  67% complete.Erasing at 0x57080000 --  68% complete.Skipping bad block at  0x582c0000
Erasing at 0x58500000 --  69% complete.Erasing at 0x59980000 --  70% complete.Erasing at 0x5ae00000 --  71% complete.Erasing at 0x5c280000 --  72% complete.Erasing at 0x5d700000 --  73% complete.Erasing at 0x5eb80000 --  74% complete.Erasing at 0x5ffc0000 --  75% complete.Erasing at 0x61440000 --  76% complete.Erasing at 0x628c0000 --  77% complete.Erasing at 0x63d40000 --  78% complete.Erasing at 0x651c0000 --  79% complete.Erasing at 0x66640000 --  80% complete.Erasing at 0x67ac0000 --  81% complete.Erasing at 0x68f40000 --  82% complete.Erasing at 0x6a3c0000 --  83% complete.Erasing at 0x6b840000 --  84% complete.Erasing at 0x6ccc0000 --  85% complete.Erasing at 0x6e140000 --  86% complete.Erasing at 0x6f5c0000 --  87% complete.Erasing at 0x70a00000 --  88% complete.Erasing at 0x71e80000 --  89% complete.Erasing at 0x73300000 --  90% complete.Erasing at 0x74780000 --  91% complete.Erasing at 0x75c00000 --  92% complete.Erasing at 0x77080000 --  93% complete.Erasing at 0x78500000 --  94% complete.Erasing at 0x79980000 --  95% complete.Erasing at 0x7ae00000 --  96% complete.Erasing at 0x7c280000 --  97% complete.Skipping bad block at  0x7cb40000
Erasing at 0x7d700000 --  98% complete.Erasing at 0x7eb80000 --  99% complete.Erasing at 0x7ffc0000 -- 100% complete.
OK
Using TSEC0 device
TFTP from server xxx.xxx.134.206; our IP address is xxx.xxx.134.209
Filename 'pkgfile/s52000tc2_0_1.pkg'.
Loading: *
TFTP error: 'File not foundö6¾' (1)
Not retrying...
. done
Erased 1 sectors
ORION>
Teck Chye Tang Thu, 04/12/2012 - 06:54
  • Cisco Employee,
Is your folder where you save all your files pkgfiles or pkgfile ?
Teck Chye Tang Thu, 04/12/2012 - 07:37
  • Cisco Employee,
In your last error, you're pointing to pkgfile. Check your command and you can see .
mindaugaskrilavicius Thu, 04/12/2012 - 23:48
Still same error. There is Log:
ORION> setenv serverip xxx.xxx.134.247
ORION> run pkgex
BOOTP broadcast 1
DHCP client bound to address xxx.xxx.134.214
save exit: isCheckpointed 1
OK
Using TSEC0 device
TFTP from server xxx.xxx.134.247; our IP address is xxx.xxx.134.214
Loading: *
TFTP error: 'File not foundô"…2' (1)
Not retrying...
. done
Erased 1 sectors
I  think the reason of this error can be - not correctly working Cisco  TFTP server, because it dont show any Logs, any activity then try upload  software.
Maybe I do something wrong.
I set for Cisco TFTP  server root address (C:\Program Files\Cisco Systems\Cisco TFTP  Server\pkgfile). Maybe need make some more in this?
Teck Chye Tang Thu, 04/12/2012 - 23:57
  • Cisco Employee,
I don't quite understand.  Or if I have understand you wrongly.   In your previous comment, you wrote :
"Folder name pkgfiles  (C:\Program Files\Cisco Systems\Cisco TFTP Server\pkgfiles)"
In your command, I still see this, the tftp_path is still pkgfile and not pkgfiles.
Teck Chye Tang Fri, 04/13/2012 - 00:11
  • Cisco Employee,
ok, then make sure all the required files are in the folder.  you might want to try to re-download the TC software and try again.  Assuming your tftp server is set up correctly and the server root directory is pointing to the server.
If still cannot, you might want to consider opening a TAC case for the TAC to assist you maybe over a web-ex session
mindaugaskrilavicius Fri, 04/13/2012 - 00:18
still same problem, - I just download new
s52000tc2_0_1.pkg
pkgextract.elf
u-boot
How we can meet web-ex session?
Teck Chye Tang Fri, 04/13/2012 - 00:20
  • Cisco Employee,
Raised a TAC case with Cisco and any available TAC will be able to advise you on troubleshooting over web-ex
mindaugaskrilavicius Fri, 04/13/2012 - 02:09
Hi again, I uploded software sucessful - Just install SolorWind TFTP server and everything become good. So Thanks for help
mubakhta Tue, 06/18/2013 - 07:02
Hi All,
I was approached by one of the customers to get a link of the document. I see that the link which is pasted here has been removed. Just updating the thread with the latest document that can be used for this method. Please refer to the following link:
https://supportforums.cisco.com/docs/DOC-27345
Please refer to the following link for the whole procedure.
Mubashshir Akhtar
TelePresence Solution Group
Related Content
