02-03-2012 04:14 AM - edited 07-03-2021 09:30 PM
I have problem with adding my demo NCS license in license center.
The file I select can’t be downloaded to NCS server
Johan Lindstrand
02-03-2012 08:46 AM
Which versin of NCS? What is the extension on the license file?
02-03-2012 09:44 AM
it's version 1.0.2.29 of NCS.
And the license file is NCSFEAT201202022xxxxxxxx.lic
02-03-2012 09:59 AM
You should be able to open up the license file in wordpad as they typically are text XML, does it open fine?
I'm assuming the UDI string matches what you registered?
02-05-2012 10:46 PM
It open just fine in wordpad.
And the UDI is my server+ S/N
