Warning message
TMS and SQL 2008 R2
Answered Question
Feb 3rd, 2012
Hello all
We're planning to migrate our SQL servers from 2005 to 2008R2. In the TMS Installation and Quick Start Guide (http://www.cisco.com/en/US/docs/telepresence/infrastructure/tms/install_guide/Cisco_TMS_Install_Getting_Started_Guide_13-1.pdf , page 6), they say that all versions of SQL 2008 are supported, but we need to be sure that this includes SQL 2008R2. Are there any limitations or considerations?
Thanks!
Correct Answer by daleritc about 5 years 6 months ago
Yes, I can confirm that the TMS sql db (tmsng) on a SQL 2008 R2 server is fine. The documentation will be updated in the next coming release.
Correct Answer by cfiestas about 5 years 6 months ago
I have seem TMS perform well with SQL 2008 R2 no issues
Overall Rating: 5 (2 ratings)
Correct Answer
cfiestas Fri, 02/03/2012 - 06:52
Correct Answer
daleritc Fri, 02/03/2012 - 07:38
  • Cisco Employee,
ma.romero Tue, 02/26/2013 - 07:05
I confirm too that Cisco TMS SQL in Windows Server 2008 is working fine. SQL is SR2.
I have in a remote SQL database.
Best regards.
