Warning message
Non-working number message
Answered Question
Feb 3rd, 2012
Is it possible to generate a message similar to "you have reached a non-working number" from within CUCM? We have a DN with corresponding DID and need CUCM to generate this message. I have tested and in a pinch we can just utilize the Telco-generated message by tearing down the DN config, but would like to do this internally if possible. CUCM v6.1(4).
Thanx
Correct Answer by Chris Deren about 5 years 6 months ago
No mailbox needed, you create a call handler for this.
Chris
Overall Rating: 5 (1 ratings)
Chris Deren Fri, 02/03/2012 - 13:45
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Do you have an voicemail system? You can send it to it and play any recording you want.
You can also define a blocking route pattern for it and it would play one of the annouciator's messages.
Chris
fjlopezderego Fri, 02/03/2012 - 13:47
I'm not sure what you want to configure but, if you configure a route pattern with the block option, you can choose between some prerecorded messages (I think there is one that says invalid number or something like that).
MBrooksAirIT Fri, 02/03/2012 - 13:57
We have Unity. But to play a VM message would imply a mailbox is configured which takes up a license correct?
The route pattern with block option is interesting. Can you point me to a config doc? or give me the steps necessary?
Thanx
Correct Answer
Chris Deren Fri, 02/03/2012 - 13:58
  • Hall of Fame,
Chris
MBrooksAirIT Fri, 02/03/2012 - 14:00
And the call handler can be either pointed to a canned message, or we can record a custom message?
Chris Deren Fri, 02/03/2012 - 14:02
  • Hall of Fame,
You would have to record it, or download something from the web and upload it as the greeting, you can even build a menu off of it, i.e. to connect to an operator press 1, etc.
HTH, please rate all useful posts!
Chris
fjlopezderego Fri, 02/03/2012 - 14:04
Hi Michael,
    You can find the doc about route pattern in http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b03rtpat.html. An example:
     1.- Configure a route pattern with pattern 1000 and any partition (there should not be any other device/dn with this number).
     2.- Check the Block this pattern checkbox
     3.- Choose one of the messages
     4.- Done. Every time a phones tries to call number 1000, it will hear the selected message and the call will be disconnected.
     If you want you can configure a route pattern with the same extension than a user's phone but a different partition so, depending on the order of the partitions in the CSS of the calling device, the call will be sent to the Route Pattern or to the phone.
fjlopezderego Fri, 02/03/2012 - 14:30
In my opinion, the route pattern is easier. The routing configuration (configure the CSSs to match the phone's DN or the Invalid prompt depending on the origin of the call) must be performed in both cases. After this configuration is done:
Option a) Create the route pattern
Option b) Create a new hunt pilot associated with the VoiceMail Hunt List (probable)
              Create and configure the Call Handler
              Record the prompt
              Configure a Direct/Forwarded Routing Rule to route the call to the Call Handler (probable)
But it's your decision!
MBrooksAirIT Mon, 02/06/2012 - 20:41
In going back over the discussion, it does appear that a route pattern with block option is probably the simpler, more elegant solution. I want to be clear though as I am somewhat confused: the message should be played for external, inbound calls to the CUCM. I configured a route pattern for the DN 1234567, set the route list, checked "Block this pattern," and selected the "Unallocated number" option. But when I call 1234567 from my cell it rings through and I am able to answer. What did I miss?
Thanx
Chris Deren Tue, 02/07/2012 - 06:01
  • Hall of Fame,
Is the route pattern assigned to a parition that is listed in the GWs Calling Search Space?
Chris
fjlopezderego Tue, 02/07/2012 - 14:14
You are probably configuring a CSS in the gateway where the dn's partition is in a higher position than the translation pattern's partition (or it is not assigned)
MBrooksAirIT Tue, 02/07/2012 - 19:46
Initially, I built the pattern with no partition. I was able to receive the call on 1234567. I then put it in a route partition that is in the GW's CSS. Still able to receive a call on 1234567. Now, this may change things a bit: the GW is a RL. That RL has a RG in it that contains both of our PRI ports. Both of these ports are in a CSS that contains the partition the route pattern is in.
