Warning message
OSFP not functioning
Answered Question
Feb 5th, 2012
I have configured the OSPF on my branch office to head office, but It's work on one branch and not working on another branch. There is no any difference in configuration except the IP address in the working and non working branches.
The ospf functioning router shows all the data when the following command given
show ip ospf database
show ip ospf neigh
show ip route ospf
The ospf not functioning router doesn't show anything when show ip route ospf issued, but it shows the data of ospf database and ospf nieghbour. What may be the problem. Please help
Mero
Correct Answer by Vivek Ganapathi about 5 years 6 months ago
Please provide the configuration + topology setup. Without this there is no way to say what problem you may be having.
Vivek
Overall Rating: 5 (1 ratings)
Reza Sharifi Sun, 02/05/2012 - 18:58
  • Cisco Designated VIP,
    2017 LAN
Please post the config from both routers.
sreenath1987 Sun, 02/05/2012 - 20:18
Hi Mero,
Please provide the output of the commands Executed by you ie:
show ip ospf neigh
show ip route ospf
Please ensure that there is no MTU Mismatch between the Routers.
You may also want to check if OSPF is configured as Point To Multi point if you are working in a NBMA type of network.
Sreenath
Vivek Ganapathi Sun, 02/05/2012 - 22:04
  • Silver, 250 points or more
Make sure you have a right network type configured on your branch router. There are many other reasons why you could have seen routes in database but not in routing table. Please provide the outputs as requested by Reza.
Vivek
Mero Cisco Sun, 02/05/2012 - 22:36
In the morning I tried for 2 hours, it doesn't work. But now it's working, no any changes have been done. What may be the problem ?
Mero
Correct Answer
Vivek Ganapathi Sun, 02/05/2012 - 22:39
Vivek
Mero Cisco Mon, 02/06/2012 - 08:48
Dear Vivek,
I have a mesh topology network. Please go through the following informations.
ne
ROUTER A#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            10.10.245.26   YES NVRAM  up                    up
FastEthernet0/1            10.10.26.1     YES NVRAM  up                    up
Loopback0                  10.10.25.26   YES NVRAM  up                    up
Router A#sh run
interface Loopback0
ip address 10.10.25.26 255.255.255.255
interface FastEthernet0/0
description ***** CONNECTED TO WAN 1 *****
ip address 10.10.245.26 255.255.255.0
ip ospf message-digest-key 1 md5 7 XXXXXXXX
duplex auto
speed auto
interface FastEthernet0/1
description ***** CONNECTED TO WAN 2 + LAN *****
ip address 10.10.246.26 255.255.255.0 secondary (WAN 2 IP ADDRESS)
ip address 10.10.26.1 255.255.255.0 (LAN IP ADDRESS)
ip ospf message-digest-key 1 md5 XXXXXXXXX
duplex auto
speed auto
router ospf 1
log-adjacency-changes
area 1 authentication message-digest
network 10.10.26.1 0.0.0.0 area 1
network 10.10.245.26 0.0.0.0 area 0
network 10.10.246.26 0.0.0.0 area 1
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.246.1 230
ip route 0.0.0.0 0.0.0.0 10.10.245.1 240
Router A#show ip ospf data
            OSPF Router with ID (10.10.25.26) (Process ID 1)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
10.10.25.24   10.10.25.24   592         0x80000045 0x00941B 1
10.10.25.26   10.10.25.26   583         0x80000010 0x00588F 1
                Net Link States (Area 0)
10.10.245.24   10.10.25.24   592         0x80000003 0x00E813
                Summary Net Link States (Area 0)
10.10.24.0     10.10.25.24   1870        0x8000003A 0x0092CB
10.10.25.0     10.10.25.24   345         0x8000000F 0x006ADC
10.10.26.0     10.10.25.26   583         0x80000007 0x00D6B6
10.10.27.0     10.10.25.24   1870        0x8000003C 0x00F91E
10.10.28.0     10.10.25.24   1870        0x8000003C 0x00EE28
10.10.32.0     10.10.25.24   345         0x8000000D 0x002121
10.10.246.0    10.10.25.24   5           0x80001BF5 0x003672
10.10.246.0    10.10.25.26   583         0x80000007 0x005957
10.10.248.0    10.10.25.24   1874        0x8000003C 0x00EBBD
10.10.25.24   10.10.25.24   1874        0x8000003A 0x00E181
10.10.25.25   10.10.25.24   349         0x8000000F 0x00BA91
10.10.25.26   10.10.25.26   587         0x80000009 0x00246C
10.10.25.27   10.10.25.24   1874        0x8000003C 0x004CD0
10.10.25.28   10.10.25.24   1874        0x8000003C 0x0042D9
10.10.25.29   10.10.25.24   1874        0x8000003C 0x0038E2
10.10.25.32   10.10.25.24   349         0x8000000D 0x0078CE
10.10.252.76   10.10.25.24   1874        0x8000003A 0x0028C8
10.10.252.220  10.10.25.24   9           0x80000001 0x0092F6
                Router Link States (Area 1)
10.10.25.26   10.10.25.26   587         0x80000003 0x00ED1F 3
                Summary Net Link States (Area 1)
10.10.24.0     10.10.25.26   587         0x80000003 0x00FE93
10.10.25.0     10.10.25.26   587         0x80000003 0x0080CF
10.10.27.0     10.10.25.26   587         0x80000003 0x006AE3
10.10.28.0     10.10.25.26   587         0x80000003 0x00er 5FED
10.10.32.0     10.10.25.26   587         0x80000003 0x003316
10.10.245.0    10.10.25.26   587         0x80000005 0x00684B
10.10.25.24   10.10.25.26   587         0x80000003 0x004E49
10.10.25.25   10.10.25.26   587         0x80000003 0x00D084
10.10.25.27   10.10.25.26   587         0x80000003 0x00BC96
10.10.25.28   10.10.25.26   587         0x80000003 0x00B29F
10.10.25.29   10.10.25.26   587         0x80000003 0x00A8A8
10.10.25.32   10.10.25.26   587         0x80000003 0x008AC3
10.10.252.76   10.10.25.26   587         0x80000003 0x009490
10.10.252.220  10.10.25.26   9           0x80000001 0x0090F5
                Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
0.0.0.0         10.10.25.251  642         0x800005A3 0x00246C 1
0.0.0.0         10.10.25.253  287         0x8000093B 0x000ACA 1
Router A# show ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.10.25.24    10   FULL/DR         00:00:37    10.10.245.24   FastEthernet0/0
The show ip ospf router does not show anything. The same kind of configuration works in another router, but over here it is not working. What may be the problem. There are lots of neighbor over this network, but can't see other network in show neighbour command, why ?
What are the commands for troubleshooting ospf ?
Mero
Vivek Ganapathi Mon, 02/06/2012 - 20:03
frankly speaking, with the above information i haven't been able to understand your setup. Is it possible for you to provide me a topology / diagram? Diagrams will help us to solve your problem much easily.
The config which you provide is it of your head office or of your branch?
Vivek
