SSL VPN - Anyconnect
Feb 5th, 2012
Trying to get this working and just will not work!  I have Cisco  Anyconnect SSL VPN and the client connects fine.  but cannot ping the  default gateway (ASA) 10.15.202.2.
From the ASA I cannot even ping the client  who gets the 1st IP address out of the pool.  What am I doing wrong?   Cisco ASA 8.4.
I have sub interfaces on my inside network and the cust1 client user needs access to 10.15.200.0/24
on ASDM logging I can see the connections being built and torn down when trying to connect from client 10.15.202.1 to hosts on the 10.15.200.0 network..  just no connectivity???
docco attached.....
Herbert Baerten Fri, 02/10/2012 - 05:40
  • Cisco Employee,
hi
to be able to ping the ip address of the ASA's cust1 interface over the tunnel, configure:
management-access cust1
As for connectivity to the LAN, I think you have your nat reversed, i.e.:
nat (cust1,outside) source static obj_10.15.202.0 obj_10.15.202.0 destination static obj_10.15.200.0 obj_10.15.200.0
should be
nat (cust1,outside) source static obj_10.15.200.0 obj_10.15.200.0 destination static obj_10.15.202.0 obj_10.15.202.0
or
nat (outside,cust1) source static obj_10.15.202.0 obj_10.15.202.0 destination static obj_10.15.200.0 obj_10.15.200.0
hth
Herbert
