ASA 5505 - No Internet Using Static NAT Rules
Jan 29th, 2012
I'm trying to configure a second server on my network but whenever I add the static NAT rule, the internet stops working on that computer.
Here's my Cisco ASA configuration:
ASA Version 7.2(3)
hostname domain
domain-name domain.ca
enable password M6aAV/2UhVYeSYwL encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.123.126 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 69.xx.xx.60 255.255.255.248
interface Vlan3
no forward interface Vlan1
nameif guest
security-level 50
ip address 192.168.226.226 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
switchport access vlan 3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd M6aAV/2UhVYeSYwL encrypted
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
access-list crypto_acl_10 extended permit ip 192.168.123.0 255.255.255.0 192.168.205.0 255.255.255.0
access-list nonat extended permit ip 192.168.123.0 255.255.255.0 192.168.205.0 255.255.255.0
access-list nonat extended permit ip 192.168.123.0 255.255.255.0 192.168.99.0 255.255.255.224
access-list inbound extended permit tcp any host 69.xx.xx.61 eq www
access-list inbound extended permit tcp any host 69.xx.xx.61 eq https
access-list inbound extended permit tcp any host 69.xx.xx.61 eq smtp
access-list inbound extended permit tcp any host 69.xx.xx.61 eq pop3
access-list inbound extended permit gre any host 69.xx.xx.61
access-list inbound extended permit tcp any host 69.xx.xx.61 eq pptp
access-list inbound extended permit tcp any host 69.xx.xx.58 eq 8080
access-list inbound extended permit tcp any host 69.xx.xx.61 eq ftp
access-list inbound extended permit tcp any host 69.xx.xx.63 eq www
access-list inbound extended permit tcp any host 69.xx.xx.63 eq https
access-list inbound extended permit tcp any host 69.xx.xx.63 eq smtp
access-list inbound extended permit icmp any host 69.xx.xx.63
access-list vpnclient_splitTunnelAcl standard permit 192.168.123.0 255.255.255.0
access-list guest_access_in extended deny ip 192.168.226.0 255.255.255.0 192.168.123.0 255.255.255.0
access-list guest_access_in extended permit ip 192.168.226.0 255.255.255.0 any
access-list guest_access_in extended permit ip any any inactive
access-list guest_access_in extended permit tcp any host 192.168.226.4
access-list guest_access_in extended permit tcp any eq smtp host 192.168.226.4 eq smtp
access-list guest_access_out extended permit ip host 192.168.226.2 host 69.70.178.122
access-list outside_access_out extended permit ip host 69.xx.xx.63 host 69.70.178.122
pager lines 24
logging enable
logging timestamp
logging monitor debugging
logging buffered errors
logging asdm warnings
mtu inside 1500
mtu outside 1500
mtu guest 1500
ip local pool remotevpn 192.168.99.10-192.168.99.20 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any guest
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0
nat (guest) 1 0.0.0.0 0.0.0.0 dns
static (inside,outside) 69.xx.xx.61 192.168.123.4 netmask 255.255.255.255 dns
static (inside,outside) 69.xx.xx.58 192.168.123.200 netmask 255.255.255.255
static (inside,outside) 69.xx.xx.63 192.168.123.58 netmask 255.255.255.255
access-group inbound in interface outside
access-group guest_access_in in interface guest
route outside 0.0.0.0 0.0.0.0 69.xx.xx.57 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa authentication ssh console LOCAL
http server enable
http 64.254.232.224 255.255.255.224 outside
http 69.70.4.112 255.255.255.248 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-AES-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 10 match address crypto_acl_10
crypto map outside_map 10 set peer 64.254.232.248
crypto map outside_map 10 set transform-set ESP-AES-MD5 ESP-AES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal  20
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh 64.254.232.224 255.255.255.224 outside
ssh 69.70.4.112 255.255.255.248 outside
ssh 69.70.178.122 255.255.255.255 outside
ssh timeout 30
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.226.4-192.168.226.100 guest
dhcpd dns 24.200.241.37 interface guest
dhcpd enable guest
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
ntp server 199.212.17.21 source outside
ntp server 199.212.17.22 source outside
ntp server 209.87.233.53 source outside
ntp server 132.246.168.148 source outside
group-policy vpnclient internal
group-policy vpnclient attributes
dns-server value 192.168.123.4
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value vpnclient_splitTunnelAcl
default-domain value domain.local
split-dns value domain.local
username mmintzberg password 8fAM98BTuTuY/jU2 encrypted
username fross password Ykti5THH7ftFZeWp encrypted
username jsilver password 0VSZ094cAtFEZuxW encrypted
username mgadmin password 3Nrrh9/fcmJrMiH2 encrypted privilege 15
username smintzberg password .RPWyyJt7YbCb94T encrypted
username smintzberg attributes
vpn-framed-ip-address 192.168.99.22 255.255.255.0
username mruiz password j8Scwuudo9vNlzVa encrypted privilege 15
tunnel-group 64.254.232.248 type ipsec-l2l
tunnel-group 64.254.232.248 ipsec-attributes
pre-shared-key *
tunnel-group vpnclient type ipsec-ra
tunnel-group vpnclient general-attributes
address-pool remotevpn
default-group-policy vpnclient
tunnel-group vpnclient ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:ca6a95011ce78d4d850a5127af0d245c
: end
Message was edited by: Moises Ruiz Updated ASA running configuration
Overall Rating: 2.6 (7 ratings)
rizwanr74 Mon, 01/30/2012 - 08:03
  • Gold, 750 points or more
the static nat you trying to add is the same public IP which is config on the outside interface?
moises.ruiz Wed, 02/01/2012 - 18:22
I'm sorry guys, I've been rushing with other stuff.
Right now I have a static NAT Rule set to 192.168.123.100 but there's no DHCP reservation for that IP, as soon as I set a DHCP reservation for the server in the Inside interface I will loose the internet.
I've updated the running configuration in my original message.
mvsheik123 Wed, 02/01/2012 - 18:35
Iam not sure if this is normal behaviour, but you can try clearing the existing 'xlate' for this single ip (local or global) after setting up the reservation.
hth
MS
mvsheik123 Wed, 02/01/2012 - 18:52
Here is the syntax...
clear xlate
To clear current translation and connection information, use the clear xlate command in privileged EXEC mode.
clear xlate [global ip1[-ip2] [netmask mask]] [local ip1[-ip2] [netmask mask]]
[gport port1[-port2]] [lport port1[-port2]] [interface if_name] [state state]
In your scenario, you can issue the command.. clear xlate local 192.168.123.200
Make sure the server still holds IP & DNS once you reserve the IP. From server end, you can release & renew IP config.
Thx
MS
moises.ruiz Thu, 02/02/2012 - 15:59
Ok I forgot how to connect and run on the exec mode but on the ASDM I executed the command and nothing changed.
i'm newbie to Cisco appliances.
lcambron Thu, 02/02/2012 - 16:37
  • Bronze, 100 points or more
Moises,
I think this is an issue with DHCP instead of NAT.
You said the issue starts when you reserve the IP.
Just to confirm the ASA is not the DCHP server for the inside network.
If you clear the arp table (after you reserve the IP of the server) and then try to access the internet, do you see arp entries on the ASA? Or can you still ping the ASA?
Felipe.
mvsheik123 Thu, 02/02/2012 - 19:36
Thanks for the update Moises. But when you reserve the IP, have you checked if the server still holds IP & DNS ?
I beiieve you need to release & renew IP config on the server.
Thx
MS
jyothydas Fri, 02/03/2012 - 02:42
static (inside,outside) 69.xx.xx.63 192.168.123.100 netmask 255.255.255.255 dns ?
Looks like wrong NAT config if you want to browse net.
static (inside,outside) 172.20.1.10 192.168.100.10 netmask 255.255.255.255 dns
!--- The "dns" keyword is added to instruct the security appliance to modify
!--- DNS records related to this entry.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968d1.shtml
moises.ruiz Fri, 02/03/2012 - 14:38
Not sure what I need to do lyothydas?
All I want is to be able to assign an static IP 9inside and outside) so that I can setup services that go to the outside world.
moises.ruiz Fri, 02/03/2012 - 14:31
The issue starts when I add the NAT rule.
No, there's a different DHCP server on the inside network.
I cleared the ARP table, I can still ping the router and the ASA and I do see entries in the ARP table.
lcambron Fri, 02/03/2012 - 15:37
Can you try the NAT without the dns keywork.
Felipe.
moises.ruiz Sat, 02/04/2012 - 13:40
I tried removing the DNS in the NAT rule but didn't change anything.
jyothydas Mon, 02/06/2012 - 01:40
You mean your command was
static (inside,outside)  69.70.71.72 192.168.123.100 netmask 255.255.255.255 and it did not work?
And you should have similar ACL which should allow http/dns commn. (Or did I miss to see it in your config)
access-list inbound extended permit tcp any any eq www
access-list inbound extended permit tcp any any eq domain
moises.ruiz Mon, 02/06/2012 - 06:24
I actually just removed: "Translate the DNS replies that match the translation rule" from the NAT Options in the ASDM and that didn't make a difference.
I do have:
(since my 192.168.123.100 NAT rule points to 69.xx.xx.63)
But I don't have:
What is that one for?
I apologize again but I'm not savy with Cisco's configuration and commands, I was not the one who configured this environment, and since it's a production environment I don't want to change stuff if I don't full understand what is doing so I appreciate your patience.
Related Content
