Call Flow Between Two SIP Gateways ?
Feb 6th, 2012
I have a little problem with SIP GATEWAY TO SIP GATEWAY. I have that topology of net:
FXS=========SIP GATEWAY====ISP====SIP GATEWAY========FXS
101        201
CME A
interface FastEthernet0/1
ip address 190.100.100.2 255.255.255.0
ip virtual-reassembly in
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 190.100.100.1
voice-port 0/3/0
voice-port 0/3/1
mgcp profile default
dial-peer voice 2000 voip
translation-profile outgoing 4Digits2E164
preference 1
destination-pattern .T
session protocol sipv2
session target ipv4:190.100.101.2
dtmf-relay rtp-nte sip-notify
dial-peer voice 15 pots
translation-profile incoming 4Digits2E164
port 0/3/0
gateway
timer receive-rtp 1200
sip-ua
authentication username cisco password 7 094F471A1A0A
retry invite 1
retry response 1
retry bye 1
retry cancel 1
registrar ipv4:190.100.100.2:5060 expires 3600
CME B
ip cef
no ipv6 cef
voice call send-alert
voice rtp send-recv
voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  bind control source-interface FastEthernet0/1
  bind media source-interface FastEthernet0/1
ip address 190.100.101.2 255.255.255.0
duplex auto
speed auto
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip route 0.0.0.0 0.0.0.0 190.100.101.1
voice-port 0/3/0
voice-port 0/3/1
preference 1
session target ipv4:190.100.100.2:5060
port 0/3/0
gateway
sip-ua
authentication username cisco password 7 0822455D0A16
retry invite 1
retry response 1
retry bye 1
retry cancel 1
registrar ipv4:190.100.101.2:5060 expires 3600
ISP
interface FastEthernet0/0
ip address 190.100.101.1 255.255.255.0
duplex auto
speed auto
ip address 190.100.100.1 255.255.255.0
duplex auto
speed auto
I have this debug when I put debug ccsip error
CME_A#debug ccsip error
SIP Call error tracing is enabled
CME_A#
SIP: (228) Group (a= group line) attribute, level 65535 instance 1 not found.
SIP: Attribute mid, level 1 instance 1 not found.
*Feb  6 17:35:39.674: //229/000000000000/SIP/Error/sipSPICheckFromToRequest:
Failed FROM/TO Request check - IGNORE IF HAIRPIN CALL
                old_from:       <sip:.[email protected]>;tag=E873B0-AF7
                old_to: <sip:.[email protected]>
                new_from:       <sip:.[email protected]>;tag=E873B0-AF7
                new_to: <sip:.[email protected]>
*Feb   6 17:35:39.686:   //229/000000000000/SIP/Error/ccsip_api_register_result_ind: Message  Code  Class 5xx Method Code 100 received for REGISTER
*Feb  6 17:35:39.686: //229/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
What is my problem?  I need your help
Can you give me some cofiguration like this, if you have ?
Thank you
Chris Deren Mon, 02/06/2012 - 11:40
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You do not need to define registar, etc between 2 CME systems, all you need to do is have the dial-peers and add the following global commands on both sides:
voice service voip
no ip address trusted authenticate
allow-connections sip to sip
HTH,
Chris
YASITAERICK Mon, 02/06/2012 - 11:53
but I want to configure two  sip gateways, and with command
registrar ipv4:190.100.101.2:5060 expires 3600 is necessary to register all points like fxs right?? And I don't have this comand
allow-connections sip to sip.
Are there any command to replace this?
Chris Deren Mon, 02/06/2012 - 11:56
  • Hall of Fame,
No, nor do I think you could do this.  The only reason you would want to do this is for integration to SIP trunk provider. All you are doing is simply integrating 2 CME systems, again all you need is dial-peers on both sides pointing to each other and global "allow-connections sip to sip" which allows IP-IP GW connectivity.
HTH, please rate all useful posts!
Chris
YASITAERICK Mon, 02/06/2012 - 12:00
well, I'm doing that demo in router 2801? But I have to realize this in AS5350. This is a getway so I want to integrate that gateway to other gateway (NET2PHONE). In this gateway there isn't that command what can I do?
thank you for your interest
YASITAERICK Mon, 02/06/2012 - 12:16
I need registrar: because I want to register with a provider:
registrar {dns:address | ipv4:destination-address}[expires seconds][tcp][secondary]:Allows a gateway to register the E.164 numbers of non-SIP phones with a registrar or proxy server.
With that command I 'm to register my FXS rigth??
Chris Deren Mon, 02/06/2012 - 12:18
  • Hall of Fame,
Do you have a SIP trunk service from your provider?  If not there is nothing you can register.
Chris
YASITAERICK Mon, 02/06/2012 - 12:28
So, with this command
registrar
Can I  register my fxs to make call or Isn't necesary realize this when I configure like this toplogy ?? I tried to simulate that
ok.
YASITAERICK Mon, 02/06/2012 - 12:30
What is the correct configuration I need only dial peers ?
Chris Deren Mon, 02/06/2012 - 12:43
  • Hall of Fame,
Simply having the "session target ipv4" pointing to the other side is what makes it work, also make sure you bind SIP protocol the IP address.
As to your 5350 GW are you saying you cannot enter the global allow command?  What IOS are you running?
Chris
YASITAERICK Mon, 02/06/2012 - 14:08
I have that ios in the AS 5350
c5350-jk9s-mz.124-15.T15.bin
YASITAERICK Mon, 02/06/2012 - 14:15
to produce like singanling in the two gateway. I need only put that right.
CME A
voice rtp send-recv
voice service voip
sip
ip http server
preference 1
port 0/3/0
gateway
sip-ua
retry invite 1
retry response 1
retry bye 1
retry cancel 1
CME B
duplex auto
speed auto
voice rtp send-recv
voice service voip
sip
preference 1
port 0/3/0
sip-ua
retry invite 1
retry response 1
retry bye 1
retry cancel 1
YASITAERICK Mon, 02/06/2012 - 14:22
Yes, I tried to put the command allow-conn... sip to sip but in this IOS that command doesn't exist. There are other command that replace ???
Related Content
