I have a B200 M5 blade that is physically stuck in the chassis.The release handle on the blade will not completely open and will not release the device.Any suggestion on how to remove it?
The content you are looking for has been archived. View related content below.
Hello UCS frinds My Question is -Can I change the Chassis/FEX discovery Policy ONLINE from "none" to "port Channel" After I set it to Port Channel i have to reacknowledge the Chassis Can I Do this online? Without intetrrupt?
OLVM requires fence agent setup for power managementAll listing of Service Profiles in the Cisco 6296 environment with B200M3's were testing fine.Listing Service Profiles : fence_cisco_ucs --ip='10.16.16.80' --username='fence-kvm-user' --password='fe...
Hello,we are performing a staging and firmware updates on a bunch of C220 M5 standalone servers delivered with CIMC 4.1(2a) loaded. After initial CIMC setup we are able to connect to CIMC GUI, all looking fine, however, we are unable to launch vKVM c...
I am installing cisco virtual connected appliance using vcenter client hosted on esxi host. I followed the installation steps from cisco (https://www.cisco.com/c/en/us/td/docs/unified_computing/Intersight/b_Cisco_Intersight_Appliance_Getting_Started_...
upon receiving power, it does in standby for a bit, before the blade health LED flashes green, and then the power button turns green, and it says that it is testing memory, before going back to standby, with a solid amber blade health LED. The RAM is...
Hi Everyone, Hope you are all good. My question is if we installed windows on bear metal blade with two vNics, let say vnic01's one primary path is Fabric-A and vnic02's primary path is Fabric-B both vnics are enable for fabric failover. In this cas...
Hi, Anyone knows if there is any way to enable TACACS+ authentication for the cisco CIMC? we have many APICS server with CIMC but theres only the option to configure AD auth. Thanks in advance
I have an environment with two FI 6248, two UCS 5108 and two 6510 brocade switches for san. UCSM has 4.0.4m version and FI are in "end host mode". We have two service profiles in use (PRD_1 & and PRD_2), both created from the same template (PRD_TE...
Hi All Can UCS FI(6454) end host mode use FC port to connect to Broade SAN SW(ds-6520b) and do port channels on both sides?
Need to replace a CPU on a UCS C240 M4 server as per https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C240M4/install/C240M4/replace.html#45480. However, the CPU that was delivered doesn't have the CPU plastic frame. So I'm not able to...
What is the recommended level of separation when one client has two physically separate UCSX setups in two sites. One site is already setup, and we're about to start the deployment for the second site. We can define a new organization, resource group...
I have a physical Windows 2022 server with one NIC connected to FI-A and another to FI-B. What is the best practice to setup NIC teaming? From Cisco doc,UCS B-Series/C-Series/S-Series/HyperFlex-Series Teaming, Bonding Options with the Cisco VIC Card ...
Hi,I'm having 5 blades on older UCSM and I want to move it to a newer UCSM/FI1st question:According to my UCSM/FI version [screenshot attached], can I move this kind of server to it :UCSB-EX-M4-12nd questions (** update : it's the most important ques...
Dear Team Please advise what Cisco SKU for VMware license replacing below SKU VMW-VSP-STD-3A= Thanks in advance
Subject | Author | Posted |
04-04-2024 11:22 AM | ||
03-18-2024 06:52 AM | ||
02-27-2024 07:34 AM | ||
02-20-2024 12:52 PM | ||
02-20-2024 10:04 AM |
