Hardware not supported - CUCM - VMWare
Answered Question
Feb 6th, 2012
Hi friends
I trying to install a CUCM 8.6  2a  in a UCS :     C210M2 , but appears this error message:
Critical Error:
The hardware you are using is not supported for this product. Installation will now halt.
What could be the problem?
Roni
Correct Answer by Aaron Harrison about 5 years 5 months ago
Have you built the virtual machine with the correct OVA file?
How much memory has the virtual machine?
Aaron
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Mon, 02/06/2012 - 22:32
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Roni Apaza Tue, 02/14/2012 - 08:07
Hi aaron,
I dont have the ova correct, but i intall this CUCM in Virtual Machine created by me.
I increased the memory form disk (70GB) and the program is installed rigth.
Thanks.
Chris Deren Tue, 02/14/2012 - 08:59
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Keep in mind in order for the system to be supported you need to use one of the Cisco provided OVAs.
Chris
alfredobosca Tue, 03/01/2016 - 00:03
Today, I have seen the same issue and incrementent the capacity of the disk.
I have a ESXi cluster (publisher/subscriber) working fine!
