7200 as VPN Concentrator
Feb 7th, 2012
Hi.
I have a 7206 as my MPLS PE.
I want to setup a remote ipsec vpn access to this and map to one of the mpls vpn/vrfs.
I will use a cisco vpn client on the remote site.
What is the minimum IOS for 7200 to run IPSEC. I find the old 12.2(31) SB16 dont have "crypto" configurations.
Also any documentation how i can configured the 7200 to match with the cisco vpn client software?
I'm trying to explore the vrf-aware ipsec but Im not sure it this will work with the cisco vpn client.
thanks
paolo bevilacqua Tue, 02/07/2012 - 05:23
  • Hall of Fame,
    Founding Member
First of all you should consider buying a crypto module for your router, otherwise it will not really work or perform very well.
ar Tue, 02/14/2012 - 23:55
Yeah I will include the module accelerator.
I'm concerned more of how to configure the 7200 as VPN concentrator for remote sites (dial-up with unknown public ip).
Also would like to use SSL.
Remote site will either use cisco or microsoft vpn clients....
Any good documentation for this?
paolo bevilacqua Fri, 02/17/2012 - 03:16
  • Hall of Fame,
    Founding Member
Plenty, and just a search click away
Come back anytime if you have specific questions...
ar Fri, 02/17/2012 - 07:31
yeah many.
Though I havent seen a solid document for vrf-aware ipsec combining dynamic-maps at static crypto peers.
I managed to test site-to-site and its working. I tested IPSEC to MPLS VPN connection.
Now I want to test dynamic-maps where the VPN concentrator will set peer as 0.0.0.0.
It's not working on my tests.
Any good docs for combining dynamic/static maps in one interface crypto-map?
