02-07-2012 06:47 AM - edited 03-21-2019 05:18 AM
Is there a way to access your messages from outside the office? I have tried *, # and looked at our options but do not see anything refering to outside access.
Solved! Go to Solution.
02-07-2012 06:59 AM
once the line stops ringing and you here the mailbox greeting you can press * to access the voicemail messages. You will be prompted to enter a mailbox number (your extension or group number) followed by the mailbox password. Hope tho helps.
02-07-2012 10:24 AM
You could also setup the Auto Attendant menu item to point to the Voicemail Pilot.
Voicemail to email can also be used for external access.
02-07-2012 06:59 AM
02-07-2012 10:24 AM
02-07-2012 10:37 AM
Thank you Navin and Ryan for the quick response. I setup the * option to transfer to a mailbox and they are able to access all from there.
