WLAN disable on a controller upgrade, why?
Answered Question
Feb 7th, 2012
I'm confused.  I'm about to upgrade a 5508 controller so I can do the pre-download to the access points, but in every doc I find, it says to disable the WLAN's before upgrading.  This makes no sense.  I'm just moving code over, why do I have to disrupt my wireless network in order to move code?
Eric
Correct Answer by Stephen Rodriguez about 5 years 1 month ago
It's kind of an old legacy of the older documentation.  No real need to do it anymore.
Steve
Correct Answer by daviwatk about 5 years 1 month ago
I too never disable my WLANs, but I know what you're talking about how it is suggested to disable all WLANs and your b/g/n, a/n networks, per the documentation.
After performing numerous upgrades across multiple platforms, I have seen, very infrequently, that WLANs may map their interfaces back to the management interface after upgrade/reboot.  I'm not sure if this was a particular release x to release y issue, but perhaps this is to help prevent this?
Regardless, nothing "bad" should happen by not doing it; just double check your config once you bring it back up.
Overall Rating: 5 (2 ratings)
Scott Fella Tue, 02/07/2012 - 09:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I never disable my wlan's when I download or reboot WLC's.
Scott Fella
Sent from my iPhone
Correct Answer
daviwatk Tue, 02/07/2012 - 10:51
  • Bronze, 100 points or more
Correct Answer
Stephen Rodriguez Tue, 02/07/2012 - 10:53
  • Purple, 4500 points or more
Steve
Michael Burk Tue, 02/07/2012 - 11:59
Although you don't have to disable the WLAN, after rebooting the controller, each AP will have to reboot so you should expect to see around 5-10 minutes of downtime depending on how many of APs you have.
I just upgraded 4 5508s last week without WLAN disable. You will be fine.
ERIC BARNETT Wed, 02/08/2012 - 12:18
Thanks for all of the assistance folks!  I appreciate it.
Leo Laohoo Wed, 02/08/2012 - 22:15
  • Hall of Fame,
    2017 LAN, Wireless
Really????  I've never read that.  It's OK.  I've just upgraded to the new 7.0.223 and it works fine.
By the way, anyone upgrading to this version will see the WAPs boot TWICE.
daviwatk Mon, 02/13/2012 - 23:52
Steps 4(optional) and 5.  This is from 7.0.230.0 Release notes.  I believe I've seen this in several release notes versions.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_230_0.html#wp844121
Step 4 (Optional) Disable the controller 802.11a/n and 802.11b/g/n networks.
Note For busy networks, controllers on high utilization, or small controller platforms it is advisable to disable the 802.11a/b/g/n networks as a precautionary measure.
Step 5 Disable any WLANs on the controller.
Trending Topics - Security & Network
