02-07-2012 12:51 PM - edited 03-16-2019 09:27 AM
Hello all.
We recently updated the firmware loads for all of the 6941 phones for a client of our and after the update, the corporate directory stopped working. I don't think that these two are necessarily related but that is the order of events in which it happened.
Things I have tried thus far:
I have checked the location that all of the phones xml files are pointing to and it is http://10.0.100.2/localdirectory which looks correct as that is the IP of
the CME router on the voice vlan. However if I browse to that location I get the attached error page.
Any ideas on where I can start with this?
Solved! Go to Solution.
02-07-2012 01:03 PM
Hi ,
I had the same problem some weeks ago when i tried to upgrade my 6921 and 6941 phones to the latest firmware 9.2.2.6.
I solved it downgrading to the previous version 9.2.1 .
N.B: If you are experiencing problems with MOH between 69XX phones , downgrade to the 9.1.1 firm.
Hope it helps
02-07-2012 01:03 PM
Hi ,
Hope it helps
02-07-2012 01:12 PM
9.2.2.6 is the firmware load we just flashed so I will stage 9.2.1 and have a phone download it and see how it goes. Thanks for the quick reply, I'll report back when I've had a chance to test.
02-08-2012 07:03 AM
Youssef,
Thanks a bunch, downgrading solved the problem. It was a relief to find a simple solution after a day of pounding my head against this problem!
02-07-2012 10:28 PM
The error is expected because the actual directlory url is slightly different.
