Signaling Protocol on UC560
Answered Question
Feb 7th, 2012
I have CP7936 phone which is running SCCP only as far as I know. I would like to know if UC560 is utilizing SCCP or SIP protocols. I never used that box. And didn't find any info about it. Is it run by Cisco Unified Communications Manager Express or Firmware like UC320?
Any help is appreciated.
Safar.
Correct Answer by Alexander Maroukian about 5 years 2 months ago
Yet only if you use FXS ports with analog conference phone as far as I am aware.
Best regards,
Alex
Correct Answer by David Trad about 5 years 2 months ago
Hi Safar,
Please be mindful of the fact that the UC-500 through CCA does not currently support SIP end points, only SIP trunks unless CCA 3.2 is to officially support this (I am not sure if it does or not).
The UC itself can support SIP end-points but only via CLI which is currently an un-supported method.
Cheers,
David.
Correct Answer by mcasimirc63 about 5 years 2 months ago
telecastle is correct and UC500 runs on Call Manager Express.
Correct Answer by telecastle about 5 years 2 months ago
As far as I know, UC500 devices support SCCP, SIP, and SPCP (Smart Phone Control Protocol, which is modified SCCP). If you want to have Cisco Small Business support on the UC500, you must configure it with CCA (Cisco Configuration Assistant), which is a GUI based configuration utility. CCA is very particular as to what features are enabled and how they are configured. It's rather restrictive compared to the plethora of options that CLI provides. If you decide to stick with CCA the only signaling protocol option for IP phones registered with UC500 is SCCP, except when you register SPA500 Series phones, SPCP is used.
If you decide to configure UC500 in CLI, you can use SIP as the signaling protocol for all of your IP phones, if you wish to do so.
Someone, please correct me if I am wrong here.
Overall Rating: 5 (4 ratings)
Correct Answer
telecastle Tue, 02/07/2012 - 14:05
Safar Safarov Tue, 02/07/2012 - 22:17
Thanks for your comments. Do you know what signaling protocol run by UC320?
Safar Safarov Tue, 02/07/2012 - 23:44
Hi Alex,
Is there any conference phone available for UC320 then?
Cheers,
Safar
Correct Answer
Alexander Maroukian Wed, 02/08/2012 - 00:32
  • Cisco Employee,
Best regards,
Alex
Correct Answer
mcasimirc63 Tue, 02/07/2012 - 17:54
  • Silver, 250 points or more
Correct Answer
David Trad Tue, 02/07/2012 - 20:23
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi Safar,
Cheers,
David.
Safar Safarov Wed, 02/15/2012 - 11:42
One more question,
can UC500 run SCCP and SPCP simultaneously in case if I have both CP7900 and SPA500 series phones in my network?
Safar.
Alexander Maroukian Wed, 02/15/2012 - 12:20
  • Cisco Employee,
Hi Safar,
You can use simultaneously both 7900 and SPA500 with UC500.
Best regards,
Alex
Related Content
