Warning message
VSMS HDD alarm
Feb 7th, 2012
Dear ALL ,
I have a customer who has a VS system contains of two media servers each one contains 12 HDD * 1 TB , one of the servers contains makes alarm sound (as beeb ) and there is one of the HDD led gives a red and all other HDD's are normal .
the VSMS is working normally but the problem in the alarm of the servers .
the customer sent me the support report of the two servers and I need to check the RAID of the servers as I think there is a problem on the RAID .
so can any one help me to check the RAID status of the two servers .
N.B the attached are the RAID files from the two servers .
Overall Rating: 3.7 (3 ratings)
Gerald Burgess Tue, 02/07/2012 - 19:02
  • Cisco Employee,
I'm guessing this is the one that's causing the beeping:
Enclosure Device ID: 16
Slot Number: 11
Device Id: 29
Sequence Number: 3
Media Error Count: 0
Other Error Count: 22
Predictive Failure Count: 0
Last Predictive Failure Event Seq Number: 0
PD Type: SATA
Raw Size: 931.512 GB [0x74706db0 Sectors]
Non Coerced Size: 931.012 GB [0x74606db0 Sectors]
Coerced Size: 930.390 GB [0x744c8000 Sectors]
Firmware state: Failed
SAS Address(0): 0x50030480006ed64f
Connected Port Number: 0(path0)
Inquiry Data:
FDE Capable: Not Capable
FDE Enable: Disable
Secured: Unsecured
Locked: Unlocked
Foreign State: None
Device Speed: 3.0Gb/s
Link Speed: 3.0Gb/s
Media Type: Hard Disk Device
Looks like it's been have problems since about the 30th.  You might want to power the server down and reseat it.  If it still doesn't work it's probably a bad drive.
lindacole Wed, 09/04/2013 - 10:27
Is there any way to silence the beeping until the drive replacement arrives?
bmathesw Wed, 09/04/2013 - 10:34
  • Cisco Employee,
# /opt/MegaRAID/MegaCli/MegaCli -adpsetprop AlarmSilence -aALL
Cory Blackman Wed, 09/04/2013 - 12:02
For those on newer v6 (and v7) Cisco has integrated the RAID Status into the Management Console, there you can check the status and Silence the Alarm.  You can add RAID Status for older v6 systems, see the great script to add in on this forum's documentation.  Please be advised that RAID disks running like these generally last between 3 to maybe 5 years imo, if one has gone bad replace it very quickly!  (And get ready for more).
Danny Mainprize Thu, 11/07/2013 - 11:00
Second on Cory's comment.  Once one goes more are close behind.  If you get 2 failures at the same time everything is lost and folks get yelled at.  I would recommend also getting configuration backups right now of all servers if you don't have already.
