TMS: Could not sync phonebook source with id 2 and name Provisioning Source
Feb 7th, 2012
Hi, I keep on getting below failure messeges. I'm new to TMS. what does below messeges mean and how do I resolve it?
Failure Reason:
Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
Event log
1/28/2010 6:53 AM - Event Created
11/21/2011 2:46 PM - Event executed by MYTMS1
11/21/2011 2:46 PM - Phonebook source Provisioning Source synchronizing
11/21/2011 2:47 PM - Event Postponed to 2009-02-05 17:23:47
11/21/2011 2:47 PM - Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
11/21/2011 2:47 PM - The event failed to complete. Details: Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
11/21/2011 5:24 PM - Event executed by MYTMS1
11/21/2011 5:24 PM - Phonebook source Provisioning Source synchronizing
11/21/2011 5:24 PM - Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
11/21/2011 5:24 PM - The event failed to complete. Details: Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
11/22/2011 5:24 PM - Event executed by MYTMS1
11/22/2011 5:24 PM - Phonebook source Provisioning Source synchronizing
11/22/2011 5:24 PM - Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
11/22/2011 5:24 PM - The event failed to complete. Details: Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
11/23/2011 5:24 PM - Event executed by MYTMS1
11/23/2011 5:24 PM - Phonebook source Provisioning Source synchronizing
11/23/2011 5:24 PM - Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
11/23/2011 5:24 PM - The event failed to complete. Details: Communication error. Could not sync phonebook source with id 2 and name Provisioning Source.
Magnus Ohm Tue, 02/07/2012 - 21:25
  • Cisco Employee,
Hi it can likely be something wrong with one or more users in the opends datadase.
I have seen a similar issue before but in order to confirm that it's related I would need to see the log-tmsagent after an attempted sync.
I recommend a tac case on this one.
Magnus Ohm Wed, 02/08/2012 - 22:58
  • Cisco Employee,
Hi Gavin
Did you raise a case on this? Is it resolved? What is the SR number?
/magnus
ib67076 Sun, 02/12/2012 - 23:14
im also seeing this error message pop up daily.
when i dig deeper, under
phonebook - manage phonebook sources - configuration - click test connection, the following error message appears:
"Unable to connect to the source: Could not connect to TMS Agent REST Service. => Unable to connect to the remote server"
phonebook - manage phonebook sources - configuration - view contacts, the following message appears:
"Unable to communicate with the TMS agent. See log (log-web.txt) for details."
when i go to log-web.txt it basically repeats the first message above.
ive just started building the tms server so (& also new to tms) i have a feeling it is something i havent enabled somewhere.
any ideas??
Magnus Ohm Sun, 02/12/2012 - 23:46
  • Cisco Employee,
Have you enabled TMSAgent under Administrative tools --> General settings?
/Magnus
gavin han Sun, 06/10/2012 - 16:30
I eventually found that the endpoint was down that's why TMS wasn't able sync up the phone book. TMS does phone book sync every 24 hrs.
