02-07-2012 07:39 PM
We have these new OS releases available:-
AsyncOS 7.5.1 build 102, 2012-01-31
AsyncOS 7.5.1 build 028, 2011-11-08
Questions;
1) Can we upgrade direct to AsyncOS 7.5.1 build 102..., 2012-01-31?
2) If something goes wrong can we revert to our current OS which is AsyncOS 7.1.5?
Best Regards,
Ruveni
02-09-2012 11:10 AM
Ruveni,
I would not upgrade to until 7.6 comes out unless you have a need to. We installed the 7.5.1-028 upgrade and it "broke" one of our filters. It was flagged MS office attached as a compressed, zipped and placing them in quarantine. It gets fixed in 7.6 but it's not available for General Release.
Doug
02-09-2012 11:35 AM
Ruveni,
We upgraded to 7.5.1-102 earlier this week and so far have not had any issues. As Doug mentioned 7.6 is finished but not available yet. So unless you are having issues with your current release you may want to wait for 7.6 to save some extra work.
Jamie
02-09-2012 03:00 PM
Thanks Doug and Jamie for responding to this thread.
Looks like there is no way of reverting to the old OS if things break.
But good to know 7.5.1-102 works so far...
02-10-2012 01:05 AM
Hello Ruven,
reverting to 7.1.5 won't be a problem, however makes sure you save your configuration with unmasked passwords before the upgrade, as revertion will reset most of your settings.
Also, you can upgrade to any version displayed directly.
Andreas
02-11-2012 02:15 PM
Hi Andreas,
Thank you very much for your reply.
Now I am interested to know the steps or commands required to ‘revert to previous version of OS’.
Looking forward to hear from you soon.
Ruveni
02-13-2012 12:39 AM
Hello Ruveni,
knowledge base article 963 has everything about reverting: http://tinyurl.com/2vzm4s
Andreas
02-13-2012 12:47 AM
Thank you very much Andreas.
Ruveni
