ASR1002 interfacing to ONS-14454 via mm fiber
Feb 8th, 2012
  • Bronze, 100 points or more
I need to interface an ASR1002 to an ONS-14454 via multimode fiber
The ASR1002 will use the 1000Base SFP-GE-S SFP module in one of the built-in Ethernet ports (in 1 of the four ports)
The ONS-14454 will use 10/100/1000Base ONS-SI-GE-SX SFP in the Ethernet expansion blade.
Cisco docs indicate each module is supported in specific ASR and ONS but does not indicate interfacing between the two.
Anyone know if these two modules will communicate without error via multimode fiber?
Tks
Frank
Reza Sharifi Wed, 02/08/2012 - 15:29
  • Cisco Designated VIP,
    2017 LAN
I Have never connect these 2 device together, but both device require SFP.  It should work fine with an LC to LC fiber patch cord.
Also fiber SFP is not 10/100/1000, it is only 1000.
SFP - 1000BASE-SX Gigabit Ethernet, 850 nm, MM, I-TEMP
ONS-SI-GE-SX=
fsebera Thu, 02/09/2012 - 06:57
Hi Reza,
Nice catch on the ONS SFP, we had already expected to run at 1000Base anyway!!!
Hopefully someone has already interfaced these two devices whit this hardware and can confirm. It's not so much the cost but the time to order, receive, and verify (several months).
Anyone else know for sure?????????????????????????????????
Tks
Frank
