DB_CRA increasing size quickly - UCCX 7.0
Answered Question
Hi All
I hope anyone can help me with this issue. After install a subscriber in telephony cluster (CUCM 7.1.3), db_cra increased it size quickly. I looked in logs for a clue but I have not  success. Before db size increased 2-4 MB per day, last day increase was 80 MB.
I will very grateful if you can help me with this issue.
Correct Answer by Gajanan Pande about 5 years 2 months ago
Luis,
db_cra is the database used for storing historical call details. Obviously, if you add new CUCM subscriber node & the agent phones registered to that node starts making/receiving calls, it would add to existing db size. This is normal.
Pls let me know if I understood the query right.
GP.
Pls rate helpful posts !!
Overall Rating: 5 (1 ratings)
Correct Answer
Gajanan Pande Thu, 02/09/2012 - 00:37
  • Cisco Employee,
Luis,
GP.
Thanks for your answer Gajanan, but I think you are wrong. In two days db, has increasing 8 %, in 7 days db will reach 2 GB that is maximum size. We installed subscriber but we did not add more agents. The only one change was register with first priority extensions in subscriber. We can wait for a increasing in db, but 100 MB per day is too much. Before, the increase was 2-4 MB per day. Calls volume per day are constant (250 calls per day aprox)
I hope somebody can help with this problem.
Rgds
Aaron Harrison Fri, 02/10/2012 - 05:45
  • Community Spotlight Award,
    Member's Choice, May 2015
Hi Luis
What were you using to monitor the size of the DB?
Is it the database content size, the database file size, or the db transaction log that is increasing?
Aaron
Related Content
