Warning message
site-to-site connection creation broke anyconnect access
Feb 8th, 2012
ASA = 8.2(1)
ASDM = 6.2(1)
Folks:
Recently I used the wizard to create an IPsec site-to-site connection, which went very smoothly; however, I now noticed that when I connect via Anyconnect 2.5.0217 I cannot get to local and subnatted resources on the network.
I rolled back to saved config file, which was taken before the site-to-site vpn was created, but that did not work as well.
What should I check to see why I can no longer get to different subnets after the site-to-site vpn connection. In addition, I thought once the old config file was applied that would have solved all my issues.
Any sugguestions or comments are welcomed...unfortunately this client does not have a smartnet account so I can't upgrade any of the items yet.
Thank you.
ajay chauhan Thu, 02/09/2012 - 05:10
  • Silver, 250 points or more
Are you able to connect anyconnect VPN ? and network access does not work then i would say check nat exempt rules.
jaz0nj4ckal Thu, 02/09/2012 - 12:34
That is correct. I am able to connect via the Anyconnect software, and I am able to PING network resources across my subnets; however, I am unable to use RPD (port: 3386) to connect to any of my servers.
I am not sure what would have changed in my NAT exempt rules, or know where to begin to look. I followed this tutorial http://www.youtube.com/watch?v=lGbsQJOxjsI
What should I look at in my ASDM? Would it be an issue with Default policy group? But I thought the Anyconnect SSL connection would not be effected since the two forms are under different categories, so the only thing I can think of, which is common between between the two is the Default Group Policy.
Julio Carvajal Thu, 02/09/2012 - 15:44
  • Purple, 4500 points or more
Can you post your configuration, so we can take a look at this issue??
Regards.
Julio
jaz0nj4ckal Fri, 02/10/2012 - 05:20
When I get to the site I will sanitize and upload the startup-config. I have to be honest, that I use the ASDM because I lack cli command knowledge, but I am working on it.
