Warning message
VPN site-to-site between ASA 5505 and 2911
Answered Question
Feb 8th, 2012
Hi all,
I'm trying to setup VPN S2S. Office router 2911 ip a.a.a.a, remote office ASA 5505 8.4(3) with ip b.b.b.b, but no luck.
2911 config:
version 15.2
service password-encryption
hostname 2911
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.152-2.T.bin
boot-end-marker
security passwords min-length 10
logging buffered 51200 warnings
no aaa new-model
ipv6 spd queue min-threshold 62
ipv6 spd queue max-threshold 63
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.22.1 192.168.22.99
ip dhcp excluded-address 192.168.33.1 192.168.33.99
ip dhcp excluded-address 192.168.44.1 192.168.44.99
ip dhcp excluded-address 192.168.55.1 192.168.55.99
ip dhcp excluded-address 192.168.10.240 192.168.10.254
ip dhcp excluded-address 192.168.22.240 192.168.22.254
ip dhcp excluded-address 192.168.33.240 192.168.33.254
ip dhcp excluded-address 192.168.44.240 192.168.44.254
ip dhcp excluded-address 192.168.55.240 192.168.55.254
ip dhcp pool desktops
import all
network 192.168.33.0 255.255.255.0
default-router 192.168.33.254
dns-server 192.168.10.10 202.50.246.41 202.50.246.42
domain-name local
netbios-name-server 192.168.10.10
netbios-node-type h-node
ip dhcp pool wi-fi
import all
network 192.168.44.0 255.255.255.0
domain-name local
default-router 192.168.44.254
ip dhcp pool DMZ
import all
network 192.168.55.0 255.255.255.0
domain-name local
default-router 192.168.55.254
ip dhcp pool voip
import all
network 192.168.22.0 255.255.255.0
domain-name local
default-router 192.168.22.254
ip dhcp pool servers
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.254
domain-name local
ip domain name domain
ip name-server 192.168.10.10
ip cef
login block-for 180 attempts 3 within 180
login delay 10
vlan ifdescr detail
crypto pki trustpoint TP-self-signed-3956567439
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3956567439
revocation-check none
rsakeypair TP-self-signed-3956567439
crypto pki certificate chain TP-self-signed-3956567439
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
license udi pid CISCO2911/K9 sn
object-group network FULL_NET
description complete network range
192.168.11.0 255.255.255.0
object-group network limited
description network without Servers and Router
vtp version 2
username admin privilege 0 password 7 password
redundancy
no ip ftp passive
crypto isakmp policy 10
encr aes 256
hash sha512
authentication pre-share
crypto isakmp key admin address b.b.b.b
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set SET esp-aes esp-sha-hmac
crypto map MAP 10 ipsec-isakmp
set peer b.b.b.b
set transform-set SET
match address 160
interface Port-channel1
no ip address
hold-queue 150 in
interface Port-channel1.1
encapsulation dot1Q 1 native
ip address 192.168.11.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Port-channel1.10
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
ip nat inside
interface Port-channel1.22
encapsulation dot1Q 22
ip address 192.168.22.254 255.255.255.0
ip nat inside
interface Port-channel1.33
encapsulation dot1Q 33
ip address 192.168.33.254 255.255.255.0
ip nat inside
interface Port-channel1.44
encapsulation dot1Q 44
ip address 192.168.44.254 255.255.255.0
ip nat inside
interface Port-channel1.55
encapsulation dot1Q 55
ip address 192.168.55.254 255.255.255.0
ip nat inside
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
channel-group 1
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
duplex auto
speed auto
channel-group 1
interface GigabitEthernet0/0/0
ip address a.a.a.a 255.255.255.224
ip nat outside
duplex auto
speed auto
crypto map MAP
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT_INTERNET interface GigabitEthernet0/0/0 overload
ip nat inside source static udp a.a.a.a 500 interface GigabitEthernet0/0/0 500
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
ip access-list extended NAT_INTERNET
deny   ip object-group FULL_NET 192.168.17.0 0.0.0.255
deny   ip object-group FULL_NET 192.168.1.0 0.0.0.255
permit ip object-group FULL_NET any
access-list 1 permit 192.168.44.100
access-list 23 permit 192.168.10.7
access-list 23 permit 192.168.44.0 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 192.168.17.0 0.0.0.255
access-list 160 permit ip 192.168.10.0 0.0.0.255 192.168.17.0 0.0.0.255
control-plane
line con 0
password 7 password
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
transport input ssh
scheduler allocate 20000 1000
end
ASA config:
: Saved
ASA Version 8.4(3)
hostname C
domain-name domain
enable password password encrypted
passwd passwd encrypted
names
interface Ethernet0/0
interface Ethernet0/1
 shutdown
interface Ethernet0/2
 shutdown
interface Ethernet0/3
 shutdown
interface Ethernet0/4
 shutdown
interface Ethernet0/5
 switchport access vlan 100
interface Ethernet0/6
 switchport trunk allowed vlan 2,6
 switchport mode trunk
interface Ethernet0/7
 shutdown
interface Vlan1
 description INTERNET
 mac-address 1234.5678.0001
 nameif WAN
 security-level 0
 ip address b.b.b.b 255.255.255.248 standby c.c.c.c
 ospf cost 10
interface Vlan2
 description OLD-PRIVATE
 mac-address 1234.5678.0102
 nameif OLD-Private
 security-level 100
 ip address 192.168.17.2 255.255.255.0 standby 192.168.17.3
 ospf cost 10
interface Vlan6
 description MANAGEMENT
 mac-address 1234.5678.0106
 nameif Management
 security-level 100
 ip address 192.168.1.2 255.255.255.0 standby 192.168.1.3
 ospf cost 10
interface Vlan100
 description LAN Failover Interface
boot system disk0:/asa843-k8.bin
ftp mode passive
clock timezone NZST 12
clock summer-time NZDT recurring 1 Sun Oct 2:00 3 Sun Mar 2:00
dns domain-lookup WAN
dns server-group DefaultDNS
 name-server 208.67.222.222
 domain-name domain
same-security-traffic permit intra-interface
object network obj-192.168.17.0
 subnet 192.168.17.0 255.255.255.0
object network obj-192.168.10.0
 subnet 192.168.10.0 255.255.255.0
object network obj-192.168.2.0
 subnet 192.168.2.0 255.255.255.0
object network obj-192.168.9.0
 subnet 192.168.9.0 255.255.255.0
object network obj-192.168.33.0
 subnet 192.168.33.0 255.255.255.0
object network obj-192.168.44.0
 subnet 192.168.44.0 255.255.255.0
object network obj_any
object network obj_any-01
object network NETWORK_OBJ_192.168.10.0_24
object network NETWORK_OBJ_192.168.17.0_24
object network subnet-00
 subnet 0.0.0.0 0.0.0.0
object-group protocol TCPUDP
 protocol-object udp
 protocol-object tcp
object-group service RDP tcp
 description RDP
 port-object eq 3389
object-group network DM_INLINE_NETWORK_1
 network-object 192.168.17.0 255.255.255.0
 network-object 192.168.10.0 255.255.255.0
 network-object 192.168.33.0 255.255.255.0
 network-object 192.168.44.0 255.255.255.0
object-group network DM_INLINE_NETWORK_2
object-group network subnet-17
object-group network subnet-2
 network-object 192.168.2.0 255.255.255.0
object-group network subnet-9
 network-object 192.168.9.0 255.255.255.0
object-group network subnet-10
access-list LAN_nat0_outbound extended permit ip 192.168.17.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list LAN_nat0_outbound extended permit ip 192.168.17.0 255.255.255.0 192.168.9.0 255.255.255.0
access-list LAN_IP standard permit 192.168.17.0 255.255.255.0
access-list WAN_access_in extended permit ip any any log debugging
access-list WAN_access_in extended permit tcp any object-group RDP any object-group RDP log debugging
access-list WAN_access_in extended permit icmp x.x.x.x 255.255.255.248 192.168.10.0 255.255.255.0
access-list MANAGEMENT_access_in extended permit ip any any log debugging
access-list OLD-PRIVATE_access_in extended permit ip any any log debugging
access-list OLD-PRIVATE_access_in extended permit icmp any object-group DM_INLINE_NETWORK_1
access-list 101 extended permit tcp host 192.168.10.7 any eq 3389 log debugging
access-list WAN_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list WAN_1_cryptomap extended permit ip 192.168.17.0 255.255.255.0 192.168.9.0 255.255.255.0
access-list WAN_cryptomap_2 extended permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list CiscoVPNClient_splitTunnelAcl standard permit 192.168.17.0 255.255.255.0
access-list LAN_access_in extended permit ip any any log debugging
access-list WAN_nat0_outbound extended permit ip 192.168.17.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list WAN_nat0_outbound extended permit ip 192.168.17.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list WAN_nat0_outbound extended permit ip 192.168.17.0 255.255.255.0 192.168.9.0 255.255.255.0
access-list WAN_2_cryptomap extended permit ip 192.168.17.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list WAN_2_cryptomap extended permit ip 192.168.17.0 255.255.255.0 192.168.9.0 255.255.255.0
access-list LAN_IP_inbound standard permit 192.168.10.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.10.0 255.255.255.0 192.168.17.0 255.255.255.0
access-list vpnusers_splitTunnelAcl extended permit ip 192.168.17.0 255.255.255.0 any
access-list nonat-in extended permit ip 192.168.17.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
logging enable
logging buffer-size 52000
logging monitor informational
logging trap informational
logging asdm informational
logging from-address syslog
logging recipient-address admin level errors
logging host OLD-Private 192.168.17.110 format emblem
logging debug-trace
logging permit-hostdown
mtu WAN 1500
mtu OLD-Private 1500
mtu Management 1500
ip local pool VPN_Admin_IP 192.168.1.150-192.168.1.199 mask 255.255.255.0
ip local pool vpnclient 192.168.2.1-192.168.2.5 mask 255.255.255.0
failover
failover lan unit primary
failover lan interface failover Vlan100
failover polltime interface 15 holdtime 75
failover key *****
failover interface ip failover 192.168.100.1 255.255.255.0 standby 192.168.100.2
icmp unreachable rate-limit 1 burst-size 1
icmp permit 192.168.10.0 255.255.255.0 WAN
icmp permit host x.x.x.x WAN
icmp permit 192.168.17.0 255.255.255.0 WAN
icmp permit host c.c.c.c WAN
icmp permit host a.a.a.a WAN
icmp deny any WAN
icmp permit 192.168.10.0 255.255.255.0 OLD-Private
icmp permit 192.168.17.0 255.255.255.0 OLD-Private
icmp permit host a.a.a.a OLD-Private
icmp permit host 192.168.10.0 Management
icmp permit host 192.168.17.138 Management
icmp permit 192.168.1.0 255.255.255.0 Management
icmp permit host 192.168.1.26 Management
icmp permit host a.a.a.a Management
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (OLD-Private,any) source static subnet-17 subnet-17 destination static subnet-10 subnet-10 no-proxy-arp
nat (OLD-Private,any) source static subnet-17 subnet-17 destination static subnet-2 subnet-2 no-proxy-arp
nat (OLD-Private,any) source static subnet-17 subnet-17 destination static subnet-9 subnet-9 no-proxy-arp
nat (Management,WAN) source static NETWORK_OBJ_192.168.17.0_24 NETWORK_OBJ_192.168.17.0_24 destination static NETWORK_OBJ_192.168.10.0_24 NETWORK_OBJ_192.168.10.0_24 no-proxy-arp route-lookup
 nat (OLD-Private,WAN) dynamic interface
access-group WAN_access_in in interface WAN
access-group OLD-PRIVATE_access_in in interface OLD-Private
access-group MANAGEMENT_access_in in interface Management
route WAN 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa local authentication attempts max-fail 10
http server enable
http b.b.b.b 255.255.255.255 WAN
http 0.0.0.0 0.0.0.0 WAN
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
service resetoutside
crypto ipsec ikev1 transform-set OFFICE esp-aes esp-sha-hmac
crypto map WAN_map 1 match address WAN_1_cryptomap
crypto map WAN_map 1 set pfs
crypto map WAN_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Office 2 match address WAN_1_cryptomap
crypto map Office 2 set peer a.a.a.a
crypto map Office interface WAN
crypto map MAP 10 set peer a.a.a.a
crypto map MAP 10 set ikev1 transform-set OFFICE
crypto ikev2 enable WAN
crypto ikev1 enable WAN
crypto ikev1 policy 10
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 30
 encryption des
 hash sha
 group 1
 lifetime 86400
telnet timeout 5
ssh a.a.a.a 255.255.255.255 WAN
ssh timeout 30
ssh version 2
console timeout 0
dhcpd auto_config OLD-Private
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ntp server 129.6.15.28 source WAN prefer
webvpn
group-policy DfltGrpPolicy attributes
 vpn-tunnel-protocol ikev1 ssl-client ssl-clientless
group-policy admin internal
group-policy admin attributes
 dns-server value 208.67.222.222 156.154.70.1
group-policy GroupPolicy_a.a.a.a internal
group-policy GroupPolicy_a.a.a.a attributes
 vpn-tunnel-protocol ikev1 ikev2
group-policy CiscoVPNClient internal
group-policy CiscoVPNClient attributes
 vpn-idle-timeout 30
 vpn-session-timeout none
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value CiscoVPNClient_splitTunnelAcl
username admin password password encrypted privilege 15
tunnel-group admin type remote-access
tunnel-group admin general-attributes
 address-pool vpnclient
 authorization-server-group LOCAL
 default-group-policy admin
tunnel-group a.a.a.a type ipsec-l2l
tunnel-group a.a.a.a general-attributes
 default-group-policy GroupPolicy_a.a.a.a
tunnel-group a.a.a.a ipsec-attributes
 ikev1 pre-shared-key *****
 ikev2 remote-authentication pre-shared-key *****
 ikev2 local-authentication pre-shared-key *****
tunnel-group CiscoVPNClient type remote-access
tunnel-group CiscoVPNClient general-attributes
 default-group-policy CiscoVPNClient
tunnel-group CiscoVPNClient ipsec-attributes
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
smtp-server 192.168.17.10
prompt hostname context
no call-home reporting anonymous
call-home
 contact-email-addr admin
 contact-name admin
 profile CiscoTAC-1
  no active
: end
asdm location c.c.c.c 255.255.255.255 WAN
asdm location 192.168.17.2 255.255.255.255 WAN
asdm location a.a.a.a 255.255.255.255 OLD-Private
ASA:
# show crypto ipsec sa
There are no ipsec sas
# show crypto isakmp sa
There are no IKEv1 SAs
There are no IKEv2 SAs
2911:
#show crypto ipsec sa
interface: GigabitEthernet0/0/0
    Crypto map tag: MAP, local addr a.a.a.a
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.10.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.17.0/255.255.255.0/0/0)
   current_peer b.b.b.b port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 4, #recv errors 0
     local crypto endpt.: a.a.a.a, remote crypto endpt.: b.b.b.b
     path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0/0
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
--More--              inbound ah sas:
--More--
--More--              inbound pcp sas:
--More--
--More--              outbound esp sas:
--More--
--More--              outbound ah sas:
--More--
--More--              outbound pcp sas:
Thanks for your time,
Nick
Correct Answer by Eugene Khabarov about 5 years 6 months ago
Please add
crypto map Office 2 set ikev1 transform-set OFFICE
If it is not helpful, please enable debug crypto ipsec 255 and paste here.
HTH. Please rate if it was helpful. "Correct answer" will be also pleasant.
Overall Rating: 5 (1 ratings)
Eugene Khabarov Wed, 02/08/2012 - 23:57
  • Silver, 250 points or more
access-list WAN_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0 access-list WAN_1_cryptomap extended permit ip 192.168.17.0 255.255.255.0 192.168.9.0 255.255.255.0
is not mirrorary equal to ACL 160 on router:
Thats the problem.
BTW ACLs WAN_2_cryptomap and  WAN_cryptomap_2 is not used anythere on ASA.
Nick Sinyakov Thu, 02/09/2012 - 00:19
Hi Evgeniy,
I've replaced access-list.
Result of the command: "show run | include WAN_1_cryptomap"
access-list WAN_1_cryptomap extended permit ip 192.168.10.0 255.255.255.0 192.168.17.0 255.255.255.0
access-list WAN_1_cryptomap extended permit ip 192.168.17.0 255.255.255.0 192.168.10.0 255.255.255.0
Tunnel is still down. In ASDM I see:
IP = a.a.a.a, Error processing payload: Payload ID: 1
Eugene Khabarov Thu, 02/09/2012 - 00:41
First, I think ikev2 is not required in tunnel-group a.a.a.a ipsec-attributes
Second, your isakmp/ike policies is incompatble betheen IOS and ASA:
On IOS:
encr aes 256
hash sha512
On ASA:
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption des
 hash sha
 group 1
 lifetime 86400
They should match.
Nick Sinyakov Thu, 02/09/2012 - 01:52
ikev2 has been removed from config on ASA, also cryptos became:
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption aes-256
 hash sha
 group 1
 lifetime 86400
Now in addition to Payload ID: 1, has been added another error:
Phase 1 failure:  Mismatched attribute types for class Group Description:  Rcv'd: Group 1  Cfg'd: Group 2
Eugene Khabarov Thu, 02/09/2012 - 02:06
Please configure on IOS:
encr aes 256
hash sha
group 2
On ASA you can try to remove:
 encryption aes-256
 hash sha
 group 1
 lifetime 86400
Nick Sinyakov Thu, 02/09/2012 - 02:30
Updated ASA config:
crypto ikev1 enable WAN crypto ikev1 policy 10 authentication pre-share encryption aes-256 hash sha group 2 lifetime 86400 telnet timeout 5
And IOS: hash sha512 -> hash sha
Now ASDM shows 1 IPSec connection, then reply with error:
IP = a.a.a.a, Received encrypted packet with no matching SA, dropping
Full log:
5|Feb 09 2012|23:20:14|713904|||||IP = a.a.a.a, Received encrypted packet with no matching SA, dropping
4|Feb 09 2012|23:20:13|113019|||||Group = a.a.a.a, Username = a.a.a.a, IP = a.a.a.a, Session disconnected. Session Type: LAN-to-LAN, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: crypto map policy not found
5|Feb 09 2012|23:20:13|713259|||||Group = a.a.a.a, IP = a.a.a.a, Session is being torn down. Reason: crypto map policy not found
3|Feb 09 2012|23:20:13|713902|||||Group = a.a.a.a, IP = a.a.a.a, Removing peer from correlator table failed, no match!
3|Feb 09 2012|23:20:13|713902|||||Group = a.a.a.a, IP = a.a.a.a, QM FSM error (P2 struct &0xcb4ce360, mess id 0x2f1dae8b)!
3|Feb 09 2012|23:20:13|713061|||||Group = a.a.a.a, IP = a.a.a.a, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 192.168.10.0/255.255.255.0/0/0 local proxy 192.168.17.0/255.255.255.0/0/0 on interface WAN
5|Feb 09 2012|23:20:13|713119|||||Group = a.a.a.a, IP = a.a.a.a, PHASE 1 COMPLETED
6|Feb 09 2012|23:20:13|113009|||||AAA retrieved default group policy (GroupPolicy_a.a.a.a) for user = a.a.a.a
6|Feb 09 2012|23:20:13|713172|||||Group = a.a.a.a, IP = a.a.a.a, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
1|Feb 09 2012|23:19:51|105009|||||(Primary) Testing on interface WAN Passed
1|Feb 09 2012|23:19:51|105008|||||(Primary) Testing Interface WAN
5|Feb 09 2012|23:19:44|713904|||||IP = a.a.a.a, Received encrypted packet with no matching SA, dropping
4|Feb 09 2012|23:19:43|113019|||||Group = a.a.a.a, Username = a.a.a.a, IP = a.a.a.a, Session disconnected. Session Type: LAN-to-LAN, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: crypto map policy not found
5|Feb 09 2012|23:19:43|713259|||||Group = a.a.a.a, IP = a.a.a.a, Session is being torn down. Reason: crypto map policy not found
3|Feb 09 2012|23:19:43|713902|||||Group = a.a.a.a, IP = a.a.a.a, Removing peer from correlator table failed, no match!
3|Feb 09 2012|23:19:43|713902|||||Group = a.a.a.a, IP = a.a.a.a, QM FSM error (P2 struct &0xcb4ce360, mess id 0x268ce1b3)!
3|Feb 09 2012|23:19:43|713061|||||Group = a.a.a.a, IP = a.a.a.a, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 192.168.10.0/255.255.255.0/0/0 local proxy 192.168.17.0/255.255.255.0/0/0 on interface WAN
5|Feb 09 2012|23:19:43|713119|||||Group = a.a.a.a, IP = a.a.a.a, PHASE 1 COMPLETED
6|Feb 09 2012|23:19:43|113009|||||AAA retrieved default group policy (GroupPolicy_a.a.a.a) for user = a.a.a.a
6|Feb 09 2012|23:19:43|713172|||||Group = a.a.a.a, IP = a.a.a.a, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Eugene Khabarov Thu, 02/09/2012 - 02:33
That's good! We are one step closer. Now it is problems with your Phase2 SAs.
Key moment here is:
BTW
crypto map MAP
is used nowhere. I suggest you to remove it from ASA's config.
Please show me once again your configs from ASA and IOS. I suppose you will modify your ACLs to look like this:
On ASA:
On IOS:
And nothing more.
Nick Sinyakov Thu, 02/09/2012 - 02:54
IOS config:
! Last configuration change at 10:17:28 UTC Thu Feb 9 2012 by admin
! NVRAM config last updated at 10:17:49 UTC Thu Feb 9 2012 by admin
version 15.2
hostname host
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
import all
domain-name local
ip dhcp pool wi-fi
import all
domain-name local
ip dhcp pool DMZ
import all
domain-name local
ip dhcp pool voip
import all
domain-name local
import all
domain-name local
ip cef
login delay 10
vlan ifdescr detail
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393536 35363734 3339301E 170D3132 30313036 30313036
  34365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39353635
  36373433 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BBBC B2F63B46 7BBC2153 2CBE7448 75C4242B F1889273 60514BBC DDE1DA56
  E39DBB15 1F287CC1 152524A5 D87A8A56 13EAFB5B B84C84AB C25D6FA4 976A2CD5
  D1A33DE0 0433C73B D4202B8B 11237BC9 D7DF4B94 826020BB 46EFD1BF 84FB7743
  9FA14E39 2725527B 7E9533AE E6785232 FC74EA73 08F60A6F 186A3637 26019E4A
  2FCB0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14AC4CB9 4112EF5F A5B1E2DF AAF07C77 25B01101 C5301D06
  03551D0E 04160414 AC4CB941 12EF5FA5 B1E2DFAA F07C7725 B01101C5 300D0609
  2A864886 F70D0101 05050003 818100B0 92B2D45B DDE83E4A 322F2091 4A098970
  63AE4657 9066FB28 74B33515 93DDD8A5 2BAD749C 5B7D3CB0 AD35C84F AE356765
  684BFFB4 0890D062 F318F65C 0DF2710E 2C31BC4F 4FEBE931 C438803B A09D2DCF
  BF9A4DC5 72DC227D 1D41F488 5382C952 0A1E4491 0A596C3B BFAEA355 5CD436DF
  7B3E69EB 5C5BEF9E 129B736F 067CB0
      quit
vtp version 2
redundancy
no ip ftp passive
encr aes 256
group 2
crypto ipsec transform-set PEER1 esp-aes esp-sha-hmac
set peer b.b.b.b
set transform-set PEER1
match address 160
no ip address
hold-queue 150 in
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
channel-group 1
no ip address
duplex auto
speed auto
channel-group 1
ip nat outside
duplex auto
speed auto
crypto map MAP
no ip http server
ip route 0.0.0.0 0.0.0.0 c.c.c.c
control-plane
line con 0
password 7 password
login
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
transport input ssh
end
ASA config:
: Saved
ASA Version 8.4(3)
hostname host
domain-name domain
names
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
nameif WAN
security-level 0
ip address b.b.b.b 255.255.255.248 standby x.x.x.x
ospf cost 10
interface Vlan2
nameif OLD-Private
security-level 100
ospf cost 10
interface Vlan6
nameif Management
security-level 100
ospf cost 10
interface Vlan100
ftp mode passive
name-server xxx.xxx.xxx.xxx
  domain-name domain
protocol-object udp
protocol-object tcp
description RDP
port-object eq 3389
pager lines 24
logging enable
logging recipient-address  level errors
logging debug-trace
mtu WAN 1500
mtu Management 1500
failover
failover key *****
icmp deny any WAN
arp timeout 14400
http server enable
encryption aes-256
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 121.98.137.77 255.255.255.255 WAN
ssh timeout 30
ssh version 2
console timeout 0
webvpn
vpn-idle-timeout 30
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
call-home
contact-email-addr
contact-name
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
asdm location b.b.b.b 255.255.255.255 WAN
Eugene Khabarov Thu, 02/09/2012 - 03:07
WAN_1_cryptomap is defined incorrectly in your last config.
Once again. On ASA:
Remove this line:
crypto map MAP
and
and
Nick Sinyakov Thu, 02/09/2012 - 03:23
All removed:
5|Feb 10 2012|00:20:42|713904|||||IP = a.a.a.a, Received encrypted packet with no matching SA, dropping
4|Feb 10 2012|00:20:42|113019|||||Group = a.a.a.a, Username = a.a.a.a, IP = a.a.a.a, Session disconnected. Session Type: LAN-to-LAN, Duration: 0h:00m:00s, Bytes xmt: 0, Bytes rcv: 0, Reason: crypto map policy not found
5|Feb 10 2012|00:20:42|713259|||||Group = a.a.a.a, IP = a.a.a.a, Session is being torn down. Reason: crypto map policy not found
3|Feb 10 2012|00:20:42|713902|||||Group = a.a.a.a, IP = a.a.a.a, Removing peer from correlator table failed, no match!
3|Feb 10 2012|00:20:42|713902|||||Group = a.a.a.a, IP = a.a.a.a, QM FSM error (P2 struct &0xcb4ce360, mess id 0x48eb296d)!
3|Feb 10 2012|00:20:42|713061|||||Group = a.a.a.a, IP = a.a.a.a, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 192.168.10.0/255.255.255.0/0/0 local proxy 192.168.17.0/255.255.255.0/0/0 on interface WAN
5|Feb 10 2012|00:20:42|713119|||||Group = a.a.a.a, IP = a.a.a.a, PHASE 1 COMPLETED
6|Feb 10 2012|00:20:42|113009|||||AAA retrieved default group policy (GroupPolicy_a.a.a.a) for user = a.a.a.a
6|Feb 10 2012|00:20:42|713172|||||Group = a.a.a.a, IP = a.a.a.a, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Correct Answer
Eugene Khabarov Thu, 02/09/2012 - 03:53
Please add
Nick Sinyakov Thu, 02/09/2012 - 13:50
Thanks Zhenya, you are the great men! The tunnel is up and I have access from office to remote network. Now I'm going to allow access from all VLANs in the office to remote network, setup keepalive for tunnel and permit reverse access from remote network to our office.
Thanks again, excellent solution!
Eugene Khabarov Fri, 02/10/2012 - 04:42
No problem. You are welcome. The best thanks is to give positive rating to my posts
onowojemma Wed, 07/18/2012 - 04:42
Hello Sir i VPN contion between ASA 5520 and 2811 router the tunnel is up and i can ping lan to lan but can not could not pass user trafic from lan to lan below is my config
Building configuration...
Current configuration : 4589 bytes
version 12.4
hostname mynet
boot-start-marker
boot-end-marker
logging buffered 52000
enable password class
no aaa new-model
memory-size iomem 10
encr 3des
group 2
crypto isakmp key 2!@$24c# address *.*.*.*
crypto ipsec transform-set test esp-3des esp-sha-hmac
crypto ipsec transform-set SDM_TRANSFORMSET_1 esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to*.*.*.*
set peer *.*.*.*
set security-association lifetime seconds 28800
set transform-set SDM_TRANSFORMSET_1
match address 100
crypto pki trustpoint TP-self-signed-2167060814
subject-name cn=IOS-Self-Signed-Certificate-2167060814
rsakeypair TP-self-signed-2167060814
crypto pki certificate chain TP-self-signed-2167060814
  3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  69666963 6174652D 32313637 30363038 3134301E 170D3132 30373034 31333431
  32365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 31363730
  36303831 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C364 7D402758 51F09695 BD154AC4 90AD2414 12EEC489 0A93144A E5F48988
  9EBEA6E8 651B2DCC 74598794 98FE7BB4 24720967 D45458E4 1B511CD9 066465C2
  6F7BABF4 BBDA2680 08058882 32E2B638 7AF69531 C29C0A90 E6346478 44729E28
  2B3A6A2B 7F9EDC55 902BC5BD 17A6D9BD EA7034FA 667714B9 014AC84D ACFBA560
  99230203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
  551D1104 19301782 15454F44 2E6E6763 2D6E6E70 6367726F 75702E63 6F6D301F
  0603551D 23041830 16801435 2811E226 99B57C71 DF7CA409 9A41978B 55CA5E30
  1D060355 1D0E0416 04143528 11E22699 B57C71DF 7CA4099A 41978B55 CA5E300D
  06092A86 4886F70D 01010405 00038181 0030C710 D435CF51 FEEC6767 45CFE3D7
  448C764A 9C394041 5B48FE3C A0973381 5A08D7CC 843D8C88 945124EA 6AB2FF07
  947F10FE 072A853B 44637E03 20AF196A 2481C0BF 89FB5B78 84E0F0F5 6D1CCDC2
  D72DFE26 E5AE679E A23CAF1A 75E4FD45 502C57D5 FA04D427 6B32FE11 E2803ADE
  6C39D9DF D59C0ADD 8BFCEBC9 92B2F514 CE
            quit
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.43.0.0 10.43.0.50
ip dhcp excluded-address 10.45.0.1 10.45.0.50
ip dhcp pool ngcph
   network 10.45.0.0 255.255.255.0
   dns-server 83.229.88.30 217.194.129.30
   default-router 10.45.0.1
   domain-name ngc-nnpcgroup.com
   lease 7
ip domain name ngc-nnpcgroup.com
username cisco privilege 15 secret 5 $1$hJFZ$/lQ9kVkbOqVVOoCs3LxlR0
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/0/0
description #ETH-WANS#
ip address *.*.*.* 255.255.255.248
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1/0
description FE int to 2nd$ETH-LAN$
ip address 10.45.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 *.*.*.*
ip http server
ip nat pool ed *.*.*.* *.*.*.* netmask 255.255.255.248
ip nat inside source route-map SDM_RMAP_1 pool ngceod
access-list 10 remark CCP_ACL Category=16
access-list 10 permit 10.45.0.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.45.0.0 0.0.0.255 10.40.0.0 0.0.255.255
access-list 101 remark CCP_ACL Category=16
access-list 101 permit ip 10.45.0.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=2
access-list 102 remark IPSec Rule
access-list 102 deny   ip 10.45.0.0 0.0.0.255 10.40.0.0 0.0.255.255
access-list 102 permit ip 10.45.0.0 0.0.0.255 any
access-list 106 remark CCP_ACL Category=4
access-list 106 remark IPSec Rule
access-list 106 permit ip 10.45.0.0 0.0.0.255 10.40.0.0 0.0.255.255
snmp-server community ngc RO
route-map SDM_RMAP_1 permit 1
match ip address 102
control-plane
line con 0
password class
login local
line aux 0
line vty 0 4
privilege level 15
password class
login local
transport input telnet ssh
webvpn cef
end
ASA
hostname MYHD-ASA
enable password NuLKvvWGg.x9HEKO encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet1
nameif inside
security-level 100
ip address 10.40.0.1 255.255.0.0
no shutdown
nameif outside
security-level 0
ip address *.*.*.* 255.255.255.240
no shutdown
interface GigabitEthernet2
nameif DMZ
security-level 100
ip address 10.50.0.1 255.255.255.0
interface GigabitEthernet3
nameif CHQWAN
security-level 50
ip address 10.60.0.1 255.255.255.252
ftp mode passive
same-security-traffic permit inter-interface
object network OUTSIDEIP
host *.*.*.*
object network NETWORK_OBJ_10.40.0.0_16
subnet 10.40.0.0 255.255.0.0
object network test
subnet 10.45.0.0 255.255.0.0
pager lines 24
mtu management 1500
mtu DMZ 1500
mtu inside 1500
mtu CHQWAN 1500
mtu outside 1500
no failover
icmp permit any echo inside
icmp permit any echo-reply inside
icmp permit any echo-reply outside
icmp permit any echo outside
asdm image disk0:/asdm-631.bin
arp timeout 14400
nat (inside,outside) source dynamic any interface
route outside 0.0.0.0 0.0.0.0 *.*.*.* 1
http server enable
http 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
no threat-detection statistics tcp-intercept
webvpn
username nnpc password St5pgJAjD4J/dO/i encrypted privilege 15
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
management-access inside
Thanks in advance for your help
Related Content
