Some questions on the aironet 1141 aironet
Feb 9th, 2012
Hi all, I'm a little confused, I have a some questions:
  1. I have several aironet 1141 device all connected to the wired LAN. Can I configure all AP so that create a single network wireless?
  2. Can I configure all AP like DHCP server with same ip pool?
Thaks all for any answer
Scott Fella Thu, 02/09/2012 - 04:46
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You can connect the aps to the same subnet. Most cases it is that way. Now you can only have one dhcp though. So if you don't have a dhcp server on the network, you can always have the switch do dhcp if it's capable or one of the AP's.
https://supportforums.cisco.com/docs/DOC-3628
http://itknowledgeexchange.techtarget.com/network-technologies/how-to-co...
andrea.lotronto Thu, 02/09/2012 - 07:51
Tanks for the answer.
I would like to go into detail of my questions, What is the configuration for the aironet for create a single big network with all APs ? I'm not found any clear documentation.
The idea of configure on all AP a DHCP server was made to solve the problem if the only DHCP server on AP is down for any reason.
Scott Fella Thu, 02/09/2012 - 08:02
  • Hall of Fame,
    2017 Wireless
You can, but you would have to split the dhcp scopes between the two AP's.
Scott Fella
Sent from my iPhone
Related Content
