DHCPv6 on Cisco 881
Answered Question
Feb 9th, 2012
Hi Guys
I am not able to activate DHCPv6 on my Cisco Router 881 (Version 15.2(2)T). There is no ipv6 dhcp ... in global config mode.
Cisco feature navigator tells me there is dhcpv6..
Router(config)#ipv6 unicast-routing
Router(config)#ipv6 cef
Router(config)#ipv6 ?
  access-list      Configure access lists
  cef                        Cisco Express Forwarding for IPv6
  flowset               Set flow label random for originated packets
  general-prefix   Configure a general IPv6 prefix
  hop-limit        Configure hop count limit
  host             Configure static hostnames
  icmp             Configure ICMP parameters
  inspect          Context-based Access Control Engine
  local            Specify local options
  nat              NAT-PT Configuration commands
  nd               Configure IPv6 ND
  neighbor         Neighbor
  port-map         Port to application mapping (PAM) configuration commands
  prefix-list      Build a prefix list
  radius           RADIUS configuration commands
  route            Configure static routes
  router           Enable an IPV6 routing process
  source-route     Process packets with source routing header options
  spd              Selective Packet Discard (SPD)
  tacacs           TACACS configuration commands
  traffic          Configure traffic parameters
  unicast-routing  Enable unicast routing
What's wrong with my box?
Correct Answer by Phillip Remaker about 4 years 10 months ago
Currently, the DHCPv6 server is only available in the Advanced IP services feature on the 800 series platform.
Here is the data sheet for feature to license mapping:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542_ps380_Products_Data_Sheet.html
I don't know if there are any plans in the future to change it, but what you are seeing today is the expected and intended behavior.
Overall Rating: 5 (1 ratings)
sfaizul Mon, 02/13/2012 - 00:17
I think you have some issues with your IOS licensing.
Cisco881W#show license all
syed
indicomekt Mon, 02/13/2012 - 00:56
Router#show license all
License Store: Primary License Storage
StoreIndex: 0   Feature: advsecurity                       Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
License Store: Built-In License Storage
StoreIndex: 0   Feature: advipservices                     Version: 1.0
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Priority: None
StoreIndex: 1   Feature: ios-ips-update                    Version: 1.0
StoreIndex: 2   Feature: WAAS_Express                      Version: 1.0
StoreIndex: 3   Feature: SSL_VPN                           Version: 1.0
        License Count: 0/0  (In-use/Violation)
I don't know wich license I need.
You are probably right.
Phillip Remaker Mon, 02/13/2012 - 16:02
  • Cisco Employee,
Are you trying to be an DHCPv6 client or a DHCPv6 server?
DHCPv6 client is an interface subcommand, not a global one.  It is activated on an interface by interface basis.
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-dhcp.html#wp1054391
DHCPv6 server is in the same license set as DHCP server (IPv4 and IPv6 should be at feature parity), so based on Feature Navigator it looks like you would need Advanced IP Services or Advanced Security license.  And you have Advanced Security.
Could be a license issue, you might want to open a TAC case.
Phillip Remaker Fri, 02/17/2012 - 09:51
  • Cisco Employee,
OK, some internal experiementation indicates that in the version you run, the DHCPv6 server is available in the Advanced IP Services feature set.  You are running the Advanced Security feature set.
It is not clear to me if this state of licensing is intentional or an oversight.  I am researching that now.  Typically, Cisco products maintain parity between IPv4 and IPv6 features within a feature set.
In the interim, you should install an evaluation license for Advanced IP Services (advipservices) to activate the DHCPv6 server.
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155619
Correct Answer
Phillip Remaker Thu, 06/07/2012 - 10:37
  • Cisco Employee,
davehopecouk Thu, 06/14/2012 - 01:17
Thanks for the update Phillip. Is there any way we can feed this back to Cisco? It seems an unusual decision to omit DHCPv6 from the Advanced Security feature set. Especially on branch-office devices like these.
Phillip Remaker Thu, 06/14/2012 - 07:49
  • Cisco Employee,
The 800 series product manager has been alerted and understands the problem, but they curently have no committed time frame to fix it.  I'll update this thread if I learn any more from them.  I also recommend filing a complaint through your sales channel and encouraging your peers with a similar issue to do the same.  Work prioritization is ultimalely driven by customer sentiment.
ktoto2ktoto Fri, 09/21/2012 - 04:56
Hi . Any progress with problem of DHCP6 server on 88x series ?  Situation really bad because RFC 6106 also not supported by cisco . So not have another way to configure ipv6 connectivity. I am little bit wondered why such feature implemented only in ADV IP.
