How to delete recurring event in DMM Scheduler?
Feb 9th, 2012
if recurring event is created by mistake and it repeats every day for a whole year, how to delete it completely? I can only delete one by one by right clicking on every item in the scheduler separately and selecting delete
Tenaro
Overall Rating: 5 (1 ratings)
Daniel Arrondo Ostiz Fri, 02/10/2012 - 02:16
Hi Tenaro,
At least in version 5.3 (not sure for older ones), if you delete a reocurring event, it will automatically delete all the instances of it.
If you version is not allowing to do it, you can try instead editting the schedule to leave only one single instance and then delete that one.
I hope this helps
Daniel
