Using "file size <>" in EEM script
Answered Question
Feb 9th, 2012
I'm working on a EEM script that saves logs to flash of the router and I'm trying to figure out a way to keep the file size under a certain limit to prevent the flash filling up from that one file. The problem now is that I'm not allowed to use the "file size <>" command in a EEM script. Anyway to get around this problem? I know this is because of the script is running in Safe-Tcl mode. Can I somehow get the scripts to run in a mode where I can use the "file size" command on a file I have created?
Correct Answer by mtimm about 5 years 4 months ago
In the EEM flavor of safe-tcl file stat is available.  You should be able to use that to get the file size.
Mike
Overall Rating: 5 (1 ratings)
Correct Answer
mtimm Thu, 02/09/2012 - 09:37
  • Cisco Employee,
Mike
Related Content
