02-09-2012 09:37 AM - edited 03-16-2019 09:30 AM
Hello All
Can anyone explain the best practises for voip and video traffic in a network that does asymmetric routing/ equal cost multipath routing?
I always thought that voip packets needed to be received in order so how does it work if the packets are being sent over different paths?
Feisal
Solved! Go to Solution.
02-09-2012 10:28 AM
In a normal, properly configured network, load sharing over different circuits happens per-flow, and never per-packet.
So packets will be always be receivied in order, and there is nothing to worry about.
02-09-2012 10:28 AM
02-09-2012 10:36 AM
