Please Newbie: Configuration of 857W VPN
Feb 9th, 2012
First, this is my first experiency with cisco routers and their configuration, so excuse me if i'm asking a silly question:
I've a local network 10.X.X.X with this router, an ADSL, and a remote office in another ISP. The remote PCs can conect to VPN, and access the router (can ping it) but can't access other devices in 10.X.X.X network.
With the problems of the SDM, Java and more, the multiple test to let the remote PCs access devices in local network, i think this configuration is totally a disaster.
Please, can anyone review it and say me what can i change (THanks!):
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname caronte
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 ###SECRET###
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authentication login ciscocp_vpn_xauth_ml_2 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_2 local
aaa session-id common
resource policy
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.1.0.0
ip dhcp excluded-address 10.1.0.255 10.255.255.254
ip dhcp pool sdm-pool
   import all
   network 10.0.0.0 255.0.0.0
   default-router 10.0.0.1
   domain-name cdi.local
   dns-server 10.0.0.3 80.58.61.250
   netbios-name-server 10.0.0.3
   lease 0 12
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name cdi.local
ip name-server 10.0.0.3
ip name-server 10.0.0.4
ip name-server 80.58.61.250
ip name-server 80.58.61.254
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
accept-dialin
  protocol l2tp
  virtual-template 1
no l2tp tunnel authentication
crypto pki trustpoint TP-self-signed-2056412050
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2056412050
revocation-check none
rsakeypair TP-self-signed-2056412050
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name [email protected]
revocation-check crl
crypto pki certificate chain TP-self-signed-2056412050
certificate self-signed 01
  ###SECRET###
  quit
crypto pki certificate chain test_trustpoint_config_created_for_sdm
username computer privilege 15 secret 5 ###SECRET###
username vvadillo privilege 15 secret 5 ###SECRET###
crypto logging ezvpn
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp key [email protected] hostname cdi.local
crypto isakmp keepalive 3600
crypto isakmp client configuration address-pool local SDM_POOL_1
crypto isakmp client configuration group CORDOBA
key ###SECRET###
dns 10.0.0.3 80.58.61.250
wins 10.0.0.3
domain cdi.local
pool SDM_POOL_1
acl Local_LAN_Access
save-password
include-local-lan
netmask 255.0.0.0
crypto isakmp profile ciscocp-ike-profile-1
   match identity group CORDOBA
   client authentication list ciscocp_vpn_xauth_ml_2
   isakmp authorization list ciscocp_vpn_group_ml_2
   client configuration address initiate
   client configuration address respond
   virtual-template 2
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ipnetconfig esp-3des esp-sha-hmac
mode transport
crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
crypto dynamic-map DYNAMIC_MAP 10
set nat demux
crypto dynamic-map ipnetconfig-map 10
set nat demux
set transform-set ipnetconfig
crypto map cisco 10 ipsec-isakmp dynamic ipnetconfig-map
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address ###EXTERNAL ADSL IP###
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
no snmp trap link-status
pvc 8/32
  encapsulation aal5snap
interface FastEthernet0
crypto map cisco
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Virtual-Template1 type tunnel
ip unnumbered FastEthernet0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
tunnel mode ipsec ipv4
interface Virtual-Template2 type tunnel
ip unnumbered Vlan1
tunnel protection ipsec profile CiscoCP_Profile1
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.0.0.1 255.0.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip local pool SDM_POOL_1 10.0.10.1 10.0.10.254
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface ATM0.1 overload
ip nat inside source static tcp 10.0.0.3 4389 interface ATM0.1 4389
ip nat inside source static tcp 10.11.0.16 21 interface ATM0.1 21
ip access-list extended Local_LAN_Access
remark CCP_ACL Category=4
permit ip 10.0.0.0 0.0.0.255 any
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 11.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=4
access-list 101 permit ip any any
no cdp run
control-plane
banner login ^C
^C
line con 0
no modem enable
line aux 0
line vty 0 4
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
