Warning message
AP over internet
Answered Question
Feb 9th, 2012
We have two WLC 5508 and i want to know if it is possible to get an accesspoint ( eg. 1131) to connect to a controller over internet, without VPN-connection. I have read documents about HREAP but that needs, if I understands it correcly, a VPN tunnel or a dedicated WAN-link. I know that ARUBA has this function, but I cant find it with CISCO.
Correct Answer by Scott Fella about 5 years 6 months ago
Yes you can. You would have to use the 1131 as an OfficeExtend AP. At least this way you can encrypt your data traffic unless you are in Russia. Take a look at the AP600 OfficeExtend configuration guide. This will show you how to setup your wlc and your SSID.
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Fri, 02/10/2012 - 05:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Scott Fella Fri, 02/10/2012 - 05:46
  • Hall of Fame,
    2017 Wireless
Just to note.... You can have the AP join in local or h-reap (if supported by the AP) without data encryption and don't need to set the ap as an OfficeExtend AP, but I would think you would want data to be encrypted over the Internet.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
