Updating ADSM
Feb 10th, 2012
I'm have upgraded our ASA 5510's from 7.0.8 to 8.4.3 and now I just need to do the ASDM, but get this error?  The bin file has been uploaded:
configure mode commands/options:
  disk0:/asa708-k8.bin    disk0:/asa843-k8.bin     disk0:/asdm-508.bin
  disk0:/asdm-647.bin     disk0:/crypto_archive
ciscoasa(config)# asdm image disk0:/asdm-647.bin
Device Manager image set, but not a valid image file disk0:/asdm-647.bin
What is the problem?
ajay chauhan Fri, 02/10/2012 - 03:01
  • Silver, 250 points or more
ASA 8.0(3)
ASDM 6.0(3) and later. Recommended: 6.4(7).
Image is Ok.
Did you change boot parameters?
show run boot
Ajay
mathieupoussin Fri, 02/10/2012 - 08:35
If you have done this before rebooting the ASA to the new firmware, this is normal, just reboot it and it should be fine
Marvin Rhoads Fri, 02/10/2012 - 19:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Your command and directory filenames look OK.
Is your asdm-647.bin file size ~17,483 KB? If not, you might want to re-download asdm-647.bin from cisco.com and re-copy it onto disk0: (after deleting the current copy).
