Warning message
SA520W does not get IP on optional WAN
Answered Question
We are using a SA520W as our primary router and have a fiber connection attached to the default WAN interface. We would like to improve our uptime using a secondary internet connection on the optional WAN interface.
We have bought a dovado tiny 4g router for this other connection. It acts as a dhcp server but the Cisco router does not get an IP from the dovado router. The router works as expected when connected to a normal computer. But somehow the cisco router doesnt get an IP.
I have also tried to set a static IP for the Cisco router but that didn't help either. The dovado router is setup do deliver ip in the range 192.168.0.2-254
Link is up but WAN state is Down. Any ideas?
Correct Answer by jasbryan about 5 years 6 months ago
Christian,
Make sure optional port is set to WAN and WAN mode = LOAD BALANCE MODE . If will not pull an ip address or negotiate a connection.
Jasbryan
Overall Rating: 5 (1 ratings)
rmanthey Fri, 02/10/2012 - 08:33
  • Bronze, 100 points or more
Hello Christian,
What is the port configuration settings, set to 10/100/1000 Half or Full. If Auto try manually changing. Also you can try to clone the mac address, or set the mdi/mdix settings on the G4 router if possible.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
Correct Answer
jasbryan Fri, 02/10/2012 - 08:39
  • Silver, 250 points or more
Christian,
Jasbryan
jasbryan Mon, 02/13/2012 - 09:07
Christian,
Auto rollover is fine - it just will not get/show an IP Address on your status until it fails over.
Jasbryan
