BGP MULTIHOMING
Feb 10th, 2012
Helo everyone,
I need help in setting up the routing policy for multihoming. The scenario is we have 1 router connected to ISPA and ISPB. For few destinations I have given higher weight attribute so that it exit through ISPA  and few other destinations through ISPB(higher weight attribute) .
How can I make sure that the reverse route is same as the forward path. For example: For Destination1 packet is  exiting through ISPA ,then how to make sure that return traffic comes through ISPA only but not through ISPB.
I hope you understand the scenario
Rooland
rooland12 Sat, 02/11/2012 - 11:31
Hi Jasper,
Thanks for the response...
But I think I can use AS path-prepaending/BGP comunities only in ACTIVE/STANDBY connection style.
In my scenario, both ISP's are active .
My requirement is that traffice going out of ISP A should return through ISP A, vice versa traffice going out throught ISP B should return through ISP B.
jgraafmans Sat, 02/11/2012 - 12:10
Routing is uni-directional so this is not possible because you cannot influence the way the returning traffic flows based on the source addres of that returning traffic.
Related Content
