Warning message
Wanting to see logging for ASA 5510 Permits
Feb 10th, 2012
I have a rule which permits traffic to a web server and logging is enabled.  But when I go to syslog I am only seeing traffic which has been
denied.  What needs to change to be able to see the logged traffic on permit rules?  Thanks.
Marvin Rhoads Fri, 02/10/2012 - 19:24
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
You might have logging globally set to something higher priority than 6 (e.g., 5 or lower numerically). What are you using to display syslog?
You can see the ACE hits using the command line by the following:
To display the hit counters and a timestamp value for an access list, use the show access-list command
in privileged EXEC mode.
show access-list id_1 [...[id_2]] [brief]
