C2960 password-recovery status show command
Feb 10th, 2012
  • Bronze, 100 points or more
Ok, so I enabled the "no service password-recovery" command on my C2960 switch.
All seems to work as discribed.
Only issue I have is --- which show command is used to reveal if the password-recovery feature is enabled of disabled as the command doesn't show up in the running config after you enable it ?
NOTE:
The command does show up in the C2960 switch in config t mode (unlike the IOS router 2800 series), but doesn't show up in the running-config after you enable or disable it.
On the 2800 series routers (latest IOS) in config t mode the command does not show up but if you type "no service passowrd-recovery" the command function correctly and it does list it in the running configuration. Strange!
Tks
Frank
Leo Laohoo Fri, 02/10/2012 - 13:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
sh version
sh run
