PIX 501 VPN HELP NO NETWORK ACCESS!
Feb 10th, 2012
I need some help please..
I am trying to connect Windows 7 VPN to L2TP access on the PIX 501. I know that PIX 501 doesn't allow MSCHAP v2. The VPN connects fine but when trying to access the local network and shared drives remote desktop I am not able to connect. I already I have the IPV4 / IPV6 IP Settings on the VPN for use default gateway on remote network unchecked.  Can you please help me configure this correctly if I am configuring incorrectly.
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd ANRIhDDsTteQmCkO encrypted
hostname pixfirewall
domain-name controller.hopto.org
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list out2in permit tcp any interface outside eq www
access-list out2in permit tcp any interface outside eq https
access-list out2in permit tcp any interface outside eq 3074
access-list out2in permit udp any interface outside eq 88
access-list out2in permit udp any interface outside eq 3074
access-list out2in permit udp any interface outside eq domain
access-list out2in permit tcp any interface outside eq domain
access-list out2in permit udp any interface outside eq 1701
access-list nonat permit ip 192.168.1.0 255.255.255.0 172.17.130.0 255.255.255.192
access-list vpn-cryptomap permit ip any 172.17.130.0 255.255.255.0
pager lines 24
logging on
logging timestamp
logging standby
logging buffered informational
logging trap informational
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool l2tp-pool 172.17.130.1-172.17.130.254
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 192.168.1.0 255.255.255.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www 192.168.1.33 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface https 192.168.1.2 https netmask 255.255.255.255 0 0
static (inside,outside) tcp interface domain 192.168.1.30 domain netmask 255.255.255.255 0 0
static (inside,outside) udp interface domain 192.168.1.30 domain netmask 255.255.255.255 0 0
static (inside,outside) tcp interface 3074 192.168.1.30 3074 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 3074 192.168.1.30 3074 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 88 192.168.1.30 88 netmask 255.255.255.255 0 0
access-group out2in in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-l2tp
crypto ipsec transform-set cisco-l2tp esp-3des esp-sha-hmac
crypto ipsec transform-set cisco-l2tp mode transport
crypto dynamic-map l2tp 30 set transform-set cisco-l2tp
crypto map dmu 30 ipsec-isakmp dynamic l2tp
crypto map dmu interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp nat-traversal 20
isakmp policy 5 authentication pre-share
isakmp policy 5 encryption 3des
isakmp policy 5 hash sha
isakmp policy 5 group 2
isakmp policy 5 lifetime 28800
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 15
console timeout 0
vpdn group 2 accept dialin l2tp
vpdn group 2 ppp authentication pap
vpdn group 2 client configuration address local l2tp-pool
vpdn group 2 client authentication local
vpdn group 2 l2tp tunnel hello 60
vpdn username Brandon password *********
vpdn enable outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd dns 4.2.2.1 4.2.2.2
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username Brandon password PX78ZeD.LCbQntqy encrypted privilege 15
terminal width 80
Cryptochecksum:6e43dff6ef4837997276c092f9204707
: end
Brandon
