Vlan (tagged)issue on a cisco ap aironet 1250 and switch hp 1905
Feb 11th, 2012
Hello everyone,
I have configured my switch using vlan 1 and 2, on ports 1-2 and 7-8 respectively. I have not mode trunk on this switch so i use hybrid port:
SwitchHP(configure)# interface ethernet 1/1
SwitchHP(configure-if)# switchport mode hybrid
SwitchHP(configure-if)# switchport allowed vlan add 1 untagged
SwitchHP(configure-if)# interface ethernet 1/2
SwitchHP(configure)# interface ethernet 1/7
SwitchHP(configure-if)# switchport allowed vlan add 2 untagged
SwitchHP(configure-if)# switchport allowed vlan remove 1
SwitchHP(configure-if)# switchport native vlan 2
SwitchHP(configure)# interface ethernet 1/8
I have to configure untagged mode on my ports because they are connected directly to a computers on mode access.
Using above configuration everything is working fine.
My problem begin when I try to connect my AP on mode trunk, because it use 2 vlans with different SSIDs, and vlan 1 like native; So, I think aironet tag vlan 2, hence i have to configure my switch port like that:
Port 1/5 from switch on mode hybrid connected by ethernet to aironet sub-interfaces 0.1 and 0.2:
SwitchHP(configure)# interface ethernet 1/5
SwitchHP(configure-if)# switchport allowed vlan add 2 tagged
SwitchHP(configure-if)# switchport native vlan 1
That is not working fine because tagged traffic from aironet is dropped for my switch, how can i solve it?
I think I can't configure vlan 2 using tag on my switch because there is a computer connected on that port and its traffic is not tagged...
AP is well configured because i have it configured like that at other location.
Thank you for your time.
Regards, Jesus.
naresh.narang Sat, 02/11/2012 - 13:54
hi there
I think AP talks to controller over wireless using LWAPP protocol, not sure about HP though. So on the switch I think all it needs is the connectivity for DHCP options.
jesusescuderolopez Sat, 02/11/2012 - 18:05
Hi naresh, thank you for your quick answer.
I don't understand very well what you're talking about, because i think my problem is about tagging options on a switch, not about dhcp protocol...
Could you explain me something more about that?
naresh.narang Sat, 02/11/2012 - 18:55
From what I understand SSIDs etc communicate with controller over wireless. As far as switch is concerned, APs receive DHCP options from controller for connectivity, so I think that switch ports can just be access ports.
ebarticel Sun, 02/12/2012 - 14:29
  • Bronze, 100 points or more
Hi Jesus,
The router-on-a-stick concept has been developed by Cisco. I don't know if it will work with third party equipment like HP.
Eugen
