Direct connect a 1721 and 1760
Answered Question
Feb 11th, 2012
I just purchased one of each of the above, both with 1ea WIC 1DSU-T1, and would like to connect them directly to each other in a lab scenario.  Do I need to have an RJ48 cable or will an RJ45 work?  I have them connected now, but they are not seeing each other. They are connected via S0 on the 1721 and S1/0 on the 1760.
This is the scenario I am using:
On 1721:
loopback 192.168.1.1/24
Fa0 172.17.1.1/24
S0 10.10.3.1/24
On 1760:
Loopback 192.168.2.1/24
Fa0/0 172.18.1.1/24
S1/0 10.10.4.1/24
On both:
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
If I missed something, please let me know, or point me to where I can get some more info.
Correct Answer by ebarticel about 5 years 5 months ago
I just want to add that the serial interfaces on both routers needs to be configured with ip addresses in same subnet.
I see that 1721 has 10.10.3.1/24 and 1760 has 10.10.4.1/24. Choose one of subnets and use, but not both.
Hope this helps
Eugen
Overall Rating: 5 (1 ratings)
mvsheik123 Sat, 02/11/2012 - 20:37
  • Gold, 750 points or more
You need T1 crossover cable to connect the WIC1DSUs. Search in your favourite engine for cable pinouts. Slightly different than Ethernet crossover.
On one side set the controller to clock source internal and the other side clock source line.
OSPF configuration is fine. It basically enables OSPF on all interfaces.
hth
MS
Correct Answer
ebarticel Sat, 02/11/2012 - 21:35
  • Bronze, 100 points or more
Hope this helps
Eugen
millerlw Sun, 02/12/2012 - 06:08
Thank you gentlemen, I appreciate your input.  I will get the T1 crossover and go from there.
Leonard
mvsheik123 Sun, 02/12/2012 - 15:14
Thanks Eugen, on same subnet on the serial links. I overlooked the ip info.
Thx
MS
ebarticel Sun, 02/12/2012 - 15:18
You welcome, glad to help
Eugen
Related Content
