Warning message
Netflow on Cat 4510R+E with IOS-XE
Feb 12th, 2012
I am trying to figure out the Flexible Net-flow on Cat 4510R+E Switch running IOS-XE code. My Neflow flow software is manageengine 7.X. I am able to see the netflow interfaces but the traffic itself is not displayed. On the Switch I can see the netflow exporter statistics counter being incremented thereby confirming as being exported.
Could anyone help me out on this ?
Don Jacob Tue, 02/14/2012 - 03:10
  • Bronze, 100 points or more
Are you using the netflow-original record or have you  created a custom flow record? For a custom record, ensure all necessary  data fields have been added. A sample config for a custom record is as  below:
cisco_281(config)#flow record ManageEngineRec
cisco_281(config-flow-record)#match ipv4 source address
cisco_281(config-flow-record)#match ipv4 destination address
cisco_281(config-flow-record)#match transport source-port
cisco_281(config-flow-record)#match transport destination-port
cisco_281(config-flow-record)#match interface input
cisco_281(config-flow-record)#match ipv4 protocol
cisco_281(config-flow-record)#match ipv4 tos
cisco_281(config-flow-record)#match ipv4 dscp
cisco_281(config-flow-record)#match  application name
cisco_281(config-flow-record)#collect routing source as
cisco_281(config-flow-record)#collect routing destination as
cisco_281(config-flow-record)#collect routing next-hop address ipv4
cisco_281(config-flow-record)#collect transport tcp flags
cisco_281(config-flow-record)#collect counter bytes
cisco_281(config-flow-record)#collect counter packets
cisco_281(config-flow-record)#collect timestamp sys-uptime first
cisco_281(config-flow-record)#collect timestamp sys-uptime last
cisco_281(config-flow-record)#collect interface output
cisco_281(config-flow-record)#collect flow direction
cisco_281(config-flow-record)#collect ipv4 id
cisco_281(config-flow-record)#collect ipv4 source mask
cisco_281(config-flow-record)#collect ipv4 destination mask
If this does not work, please try with the "netflow-original" record.  You can see the  config example under the sample config section in the  below blog (though it is for Nexus, the flow record, exporter and  monitor part should work)
https://blogs.manageengine.com/netflowanalyzer/2010/05/06/cisco-nexus-and-netflow-analyzer-bandwidth-monitoring
If that too fails, support team at ManageEngine ([email protected]) should be able to help.
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
jakewilson Tue, 02/14/2012 - 12:00
I hope Don's suggestion helps.
If you can't get it working, send me a packet capture and I'll run it through Scrutinizer NetFlow Analyzer to see if i can figure it out.
Jake
