NBAR configuration for specific Vlan to throttle youtube
Answered Question
Feb 12th, 2012
I am trying to throttle http traffic for a specific network utilizing a policy-map and class-maps.  What I am trying to do is limit facebook, youtube, etc for a specific vlan but allow others to pass unmetered.  I have class-maps that match the http hosts which work fine and I have a class-map that matches the source network but I cannot seem to get it to match both at the same time.  Does anyone have a sample config that will match a source network and http host and apply a policer or priority to both?  So basically I just want to slow down youtube and facebook for the network below.
vlan IP 192.168.30.0/24
websites *youtube* *facebook* *fbcdn*
Thank you all for your support and assistance.
Mike
Correct Answer by Dan-Ciprian Cicioiu about 5 years 4 months ago
ALL-SOURCES will match url list and any source but not the 192.168.30/24 ( match not access-group name )
POLICE-WWW will match url list and source 192.168.30/24
"priority" it is used for LLQ ( low latency queueing ) usually to prioritize the VOIP traffic . If you want to limit the traffic you better use shaping or policing. Policing will drop any excees traffic , Shaping will try to queue the excess traffic adding some latency. I would use policing :
policy-map filter
class ALL-SOURCES
   police rate 10000000
class POLICE-WWW
   police rate 1000000
Dan
Overall Rating: 5 (1 ratings)
Dan-Ciprian Cicioiu Sun, 02/12/2012 - 01:58
  • Gold, 750 points or more
Hi ,
The policy-map works by the first match. I think that the problem is that if you have the first class-map matching all the www traffic , this class-map will match also the "unwanted vlan source". So you should deny the IP sources that you want to police. Your config should look like :
ip access-list stan ACL-VLAN30
  permit 192.168.30.0 0.0.0.255
class-map match-all ALL-SOURCES
  match no access-group name ACL-VLAN30
  match protocol http url "*facebook*" "*youtube*" "*fbcdn*"
class-map match-all POLICE-WWW
  match access-group name ACL-VLAN30
Dan
spartain Sun, 02/12/2012 - 02:05
Thanks for the reply,
would the policy-map just match ALL-Sources then POLICE like?
policy-map filter
class ALL-SOURCES
     priority 10000000  (10mb)
class POLICE-WWW
     priority 1000000 (1mb)
Am I thinking about this right?
Thanks again, this has been a challenge for me.
Correct Answer
Dan-Ciprian Cicioiu Sun, 02/12/2012 - 02:26
policy-map filter
class ALL-SOURCES
class POLICE-WWW
   police rate 1000000
Dan
spartain Sun, 02/12/2012 - 02:29
Perfect! I will test this out tomorrow. Thanks for the help and the quick response!
Much appreciated!
Mike
