Warning message
SG300-28 IPv4 Static routes
Feb 13th, 2012
I've looked at the demo manual (Demo script nijkola 300-series v6 ) to configure two different ports on two different VLAN and make them availables, but I can't get it work.
I kindly ask how static routes work, because I got the same config as in the demo manual, but still can't
ping from the PCs connected.
2)What means route type Local, and remote? Why if I add a new route it goes to remote?
3)The gateway ip configured on the PCs must be the Switch ip, to connect to the internet where can I configure the real gateway for those PCs?
4)Adding a new static route with destination Ip (PC2)  netmask 255.255.255.0 and next hop (PC1) still can't ping.
I'm not a pro, please give some advices, thanks
jasbryan Mon, 02/13/2012 - 09:04
  • Silver, 250 points or more
88Summer,
If would be best for you to call SBSC @ 1-866-606-1866 and open a support case so we can get a better idea on what you are trying to accomplish. What all devices are you trying to implement within your topology?We can assist you in verifing  routes and other devices are configured.
Jasbryan
Related Content
